Buick regal 1994 3.8L . Parked the car the other day. Went to start it 2 days later, It turns over fine but won;t start, doesn;t even seem to fire at all, just a dead rollover. Does this soiund like a sensor problem? If so how do I get the codes from it?
Thanks, ~ Leonard |
Re: Won't Start
First, check to see if you are getting spark to the plugs. If not then you need to check the ignition module. You also need to find out of there is any fuel. I had a Ford that ran just fine one day and the next day the car would not start. Turned over fine had plenty of spark. The fuel pump died and had to be replaced. I don't think there is any sensor that would cause the car not to start. Total computer failure maybe but not one sensor. Check the above and post again. Good Luck!
