| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
Acceleration Problem with '98 Maxima
Hey Guys!
Thanks for helping me with my remote problem. I have a 98 maxima SE with automatic transmission. When I press on a gas above 30mph it does not respond right away and most of the time nothing happens until I press the pedal really hard. Its like there is a gap. I recently chaged air filter, oil, oil filter, spark plugs and gas filter. I have no idea what could possibly cause this. Please help Thank you |
Re: Acceleration Problem with '98 Maxima
Might want to check your ECU for ghost codes such as 0304 which is the knock sensor needing replacement.
~THT |
Re: Re: Acceleration Problem with '98 Maxima
Thank you for your response. I would appriciate if you can explain a little more how exactly i should do it. I know where the ECU is and thats about it.
Thank you |
Hi I had similiar problems about a month ago I replaced my knock sensor and ECT sensor and all is well.... Maybe these links will be of help to you, Good luck....
http://www.vbxmaxima.8m.com/ecu.html http://www.vbxmaxima.8m.com/ecudecoder.html http://www.motorvate.ca/mvp.php/507 |
Thank you
I will check the knock sensor. |
I just realized that the ecu decoder page is messed up... I did e-mail asking when it will be available and I am waiting on a response as soon as I find out some info I will gladly post...
I have the Haynes manual; post your codes and I'll interpret them
~THT |
I got it, its 0304 - knock sensor. I guess I will have to change it. Should I go to nissan center to run the tests or you suggest i should just buy the sensor and install it?
Just replace it. Get the part from www.jerryromenissan.com and use the promo code "MAXIMA"; should come out to $110-$120 shipped. Then, use the following tutorials to change it:
http://www.skippynet.com/maxima/knocksensor.htm http://www.motorvate.ca/mvp.php/507 ~THT |
Thank you very much for your help guys. I will do as you recommended.
don't replace the knock sensor its not your problem and won't be your problem it doesn't do anything you can have that code from new dealers don't even fix it you got other issues before wasting your money
96 gt bbk x-pipe lakewood traction bars american thunder cat back march ram air k&n richmond gears 97 maxima in progress |
What other issues? Please explain... |
there is a tsb ntb98-111a it calls for an ecm to be replaced if u give it gas and it hesitates then kicks in replace ecm to resolve it
I have always wanted to know what are the sensors which unless they are dead completely you will not see a code in ECu.
I mean you could have one/some sensors with out of range readings however ECu is showing normal operation code. I know throttle position sensor is one of them. Does anybody know more.
well tps will set a code and affect your trans performance u might not see a code for it but u will see like at 1st function code that is tps related but knock sensor barely does anything.
