Old 09-18-2004, 07:31 PM
zuk808 zuk808 is offline
whining noise
I have a 98 s-10 2.2 Its making a whining noise, like a power steering pump but with no change in noise when resistance is applied to the steering wheel. I changed it any ways but the noise is still there. Tried the stethescope thing but stiil can't pin point the location. The noise is constant and goes up and down with rpm. any ideas on where I should go next??
Old 09-18-2004, 08:04 PM
tom3 tom3 is offline
Re: whining noise
Possibly a bearing in one of the idler pulleys. They are pretty small and turn really fast, wear out quick. Take off belt and spin them. Any noise or felt roughness, replace it.
Old 09-18-2004, 08:10 PM
brad_26 brad_26 is offline
Send a message via AIM to brad_26 Send a message via Yahoo to brad_26
good
i had the same problem and i will try the ting u sugested to thanks
Old 09-18-2004, 10:07 PM
OverBoardProject OverBoardProject is offline
Banned
Re: whining noise
usually if you can safely give the idler bearings a quick squirt with some lube while the engine is running will quiet them down, and reveal the faulty bearing
Old 09-19-2004, 07:27 AM
port48 port48 is offline
Re: whining noise
You could try removing the belt and running the engine just long enough to see if the noise goes away.
Old 09-20-2004, 10:46 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: whining noise
Probably an alternator going.
Old 09-20-2004, 06:21 PM
Mikado14 Mikado14 is offline
Re: whining noise
Here's a thought, just in case you don't find a bad pulley bearing, perhaps the alternator is charging at a high current because your battery is going downhill. With the engine off, unplug the alternator, you can leave the heavy positive hooked up. Start the engine and see if the whinning went away. If it did, it's normal. Have a load test done on the battery.
Old 09-20-2004, 06:58 PM
BassBlazer427 BassBlazer427 is offline
i had a groaning whining sound.....was told it was the idler pulley...
the large grey/silver looking one at the top of the motor in the center....had it replaced....sound gone
Old 09-21-2004, 12:36 PM
Talking
replaced the idler on the tensioner, fixed the problem. Thanks for the help.
