Go Back   Automotive Forums Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 09-18-2004, 06:28 PM
hanman06 hanman06 is offline
diy painting
Hey,
I'm thinking about painting a rear fender on my Accord after I repair some minor rust. I have access to an airless spray gun to paint, but no access to a real spray booth. Does anyone have any links or suggestions on painting a car in your garage/driveway, as well as info on how to get a good finish? Any help is great,
Thanks
Mike
Old 09-18-2004, 06:44 PM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
Re: diy painting
Yes painted my whole body kit, spoiler, trunk and hood myself in my garage. Cleaned the area removed everything bought clear sheets of plastic (painters plastic) from home depot. Hung it from the ceiling, down making a sqaure enclosed area for me to paint. Dont have any fans blowing cause it will only blow dust on your paint. Repair your rust sand it down prime it and paint it a few times then throw a clear coat on. It wont be factory, but if you do it right it comes out dame near. My link in my sig has my old car I painted..-good luck
Old 09-18-2004, 09:43 PM
Thanks for your advice. I was just wondering if you used an aerosol can or a compressed air spray gun? Also, would I have to paint the whole panel or just the area where I fixed the rust? Thanks again.
Old 09-19-2004, 11:13 AM
Beastiek2's Avatar
Banned
Re: diy painting
The whole panel so the paint blends. You wanna use a gun on things like that an aerosol can will look shi**y.
Old 09-19-2004, 11:26 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: diy painting
Theres aeresol paints that work just as well as using a professional paint gun. The product line is called Dupli-Color the cans have a buetiful spray tip that puts the paint on nice and evenly and since its the same type of paint the car was factory painted it blends well when doing portional touch ups or whole panels. Unless you got alot of skill with blending paint and polishing I would definately paint the whole panel. Sherwin Williams has the patent on these paint match products. I use it when doing metal finish repairs on our lot vehicles that were previously bagged I dont paint entire portions i just touch it up with the product and put clear coat on it. Its alot cheaper than buying equiptment and requires less prepping and does not require a booth simple news paper to and masking tape is all you need. Dont do it outside cus the wind could make it messy.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 09-19-2004, 02:09 PM
Beastiek2's Avatar
Banned
Re: diy painting
Could end up being cheaper to have it done at a shop - If you were to buy the gun/compressor/paint.
I wouldnt trust aeresol cans on the exterior parts of the car, I have no experience with that.
Old 09-20-2004, 09:33 AM
Xesss's Avatar
Xesss Xesss is offline
Re: diy painting
water down teh floor before painting to reduce the chances of dust getting on the paint. from what i heard.
Old 09-23-2004, 10:34 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: diy painting
aerosol cans arent that bad, you just have to be good with them. And i think duplicolor isnt that good. Krylon is the way to go, even though they dont have exact matches. Duplicolor is alright, but it isnt as smooth as Krylon.
1991 Honda Civic DX Sedan
Old 09-24-2004, 09:05 AM
Re: diy painting
Dupli Colors exact match is very good they use the exact same paint in the can as they did on the car in the factory , not many folks realize this but sherwin williams paint is excellent stuff and was used widely in the auto manufacturing industry. The years available are from 2002 and under for most makes and models (exact match line) but for newer they changed to another paint line up.
Old 12-15-2004, 11:51 PM
gearsforbrains gearsforbrains is offline
Send a message via AIM to gearsforbrains
if you use aerasol clear coat and do about 5 coats can u buff an aerasol clear coat..?
Old 12-18-2004, 05:42 PM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
Re: diy painting
Krylon over Dupli-Color? I don't think so.
I've had experience with both, and Dupli-Color lays it down SO much better.
The ONLY positive I can think of for Krylon is that it dries in 12 minutes...
