Old 09-18-2004, 06:11 PM
Chrismckitt Chrismckitt is offline
Send a message via AIM to Chrismckitt Send a message via Yahoo to Chrismckitt
help! whats wrong
Engine won't rotate, just stoppped one day and now It seems locked up. What usually keeps a engine from turning. It does nothing when u turn the key. Something internal I'm sure, but where to start looking, head?
Old 09-18-2004, 06:14 PM
cbell77 cbell77 is offline
Re: help! whats wrong
do you have a cold air intake? Check battery Check spark plugs and wires, Check starter. Need more info
1966 mustang for sale asking $7900 call 757-766-3702
Old 09-19-2004, 02:46 AM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
if the engine isnt turning over because it locked up then yeah.. id guess theres some very complicated very expensive problem just waiting for whoever tears it apart... but i could be wrong
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-19-2004, 05:56 AM
joemathews's Avatar
joemathews joemathews is offline
Why are you jumping to say that it's something internal. It could be something as simple as your starter or ignition switch or fuse. If there is more info you're leaving out, it is not helping us help you.
1996 Eagle Talon
Old 09-19-2004, 01:54 PM
Re: Re: help! whats wrong
Forgot to mention that I tried rotating the engine at the crank pulley, it turns a little then stops.
Old 09-19-2004, 02:04 PM
joemathews's Avatar
Are you sure it's not in gear?
1996 Eagle Talon
Old 09-19-2004, 02:07 PM
yeah its not in gear, I had a weird rattle at high rpms in the head and one day my car just quit, checked everything externally, but figured maybe something broke inside the head jambing the engine?
Old 09-19-2004, 09:26 PM
northriverflames northriverflames is offline
Send a message via MSN to northriverflames
Try taking ur spk plugs out and then turning the motor over, one of ur injectors may have failed and hydralocked the motor, happened to a friend of mine a couple weeks back!
Old 09-19-2004, 09:30 PM
macder macder is offline
Send a message via MSN to macder
if its a 5-speed, have u tried rolling the car w/ignition on and putting the car into 2nd gear and droping clutch? If this doesnt work u have a problem
Old 09-19-2004, 09:41 PM
gstclips gstclips is offline
Send a message via AIM to gstclips
do you have any check engine lights on in your gauge cluster?
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 09-19-2004, 11:22 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Originally Posted by [url="http://www.automotiveforums.com/vbulletin/member.php?u=233717"
Chrismckitt[/url]] Forgot to mention that I tried rotating the engine at the crank pulley, it turns a little then stops.
Are you sure that it just stops?, cause don't forget that the engine have compression and it will make your crank pulley gets harder to move.
Originally Posted by [url="http://www.automotiveforums.com/vbulletin/member.php?u=172129"
gstclips[/url]] if its a 5-speed, have u tried rolling the car w/ignition on and putting the car into 2nd gear and droping clutch? If this doesnt work u have a problem
Try that, it's a good idea
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 09-20-2004, 12:57 PM
Yeah I know the engine has a compression stroke, but I turned a few motors by hand and the compression side is not that hard to turn, plus I marked the cam gears and hit the ignition and they turned until they got to about 3/4 the of the way around, then I hit the switch more and the gears won't move! It's pissing me off!
Old 09-20-2004, 03:59 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
crack it open....
start tearing suff apart and see what is fucked up!
Old 09-20-2004, 05:32 PM
Originally Posted by BoostedSpyder
crack it open....
starting tearing it down and found one weird thing already, the #1 spark plug the end where it turns white is broke off! All the other plugs are fine.
