Old 09-18-2004, 04:46 PM
shooterc5 shooterc5 is offline
Send a message via AIM to shooterc5
99 GTP lacking power
Hello
I have a 99 gtp and it seems to be lacking power. I bought it used with 80k on it and the engine runs fine no codes no hesitation everything seems normal except the power. If i start from a complete stop turn of the trac control and floor it it wont break the tires loose they wont even squeal. My buddy has a stock 2000 gtp and his will roast them with no problem. My car is stock also stock and i just replaced the plugs, wires, fuel filter, pcv valve, and air cleaner. transmission also shifts fine. One thing i did notice on my buddys gtp is that if i rev it to 3500 real quick in neutral it wil show a little boost on the guage mine does not do this. But it will register if im already moving and floor it, but doesnt go all the way to full boost. My buddies does. Could this be a boost control valve problem? If anyone could help me out i would appreciate it.
Old 09-18-2004, 09:44 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Might try doing the boost control mod and see if that helps pick it up a bit more,might be that the factory set it off a bit.The link is dead now but when it comes back up I will post it ....~Larry~
ClubGP Member 6530
Since 2001
Old 09-18-2004, 10:46 PM
thanks alot
once u get the link back up ill try that unless you want describe it in text sweet ride by the way
Old 09-20-2004, 10:05 AM
BIG-L's Avatar
Thanks..The link is still down,sorry.They might have been hit by the storm and not have power.Here is the link,just keep trying untill it's up......~Larry~
http://www.mccgp.com/upgrades/boostb...ost_bypass.php
ClubGP Member 6530
Since 2001
Old 09-20-2004, 03:10 PM
Cool thanks larry
I anyone has anyother suggestions what so ever please post them they will really help me out im stuck here. anyone else ever had this problem either?
Old 09-21-2004, 11:27 AM
wow thanks a million larry that did the trick! the factory set it off a half inch or more.
Old 09-21-2004, 11:33 AM
BIG-L's Avatar
Glad it worked out for you,just take it easy on those tires
~Larry~
ClubGP Member 6530
Since 2001
Old 09-21-2004, 11:44 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: 99 GTP lacking power
Big-L,
How did you become a member of the Detroit GP Club? I wrote them and they told me you have to live in the area. How did you pull that off?
Old 09-21-2004, 11:58 AM
BIG-L's Avatar
Im not a member of there club ...Ive just gota lot of links for mods.Ive saved alot of them thru the years of being a ClubGP member since 2001 and was a guest when I found the site in 2000 before I made my first post in 5/9/2001.
~Larry~
ClubGP Member 6530
Since 2001
