Old 09-18-2004, 04:04 PM
lorunner lorunner is offline
Question Ungluing Headlamps/Taillamps?
Anybody got any good tricks on how to get a taillight or a headlight housing apart?
I tried the heat gun once before and its pretty tricky, to hot and you melt the plastic.
I heard about putting them in the oven from a friend but he doewn't know the specifics.
Old 09-18-2004, 04:36 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: Ungluing Headlamps/Taillamps?
Oven? That would melt the whole thing. Don't do that.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 09-18-2004, 04:41 PM
No he said put it on low for so many minutes. Definately not on 450 degrees
Old 09-18-2004, 04:45 PM
Shaguar47's Avatar
well, either way, it's a risk.
Old 09-18-2004, 06:25 PM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
Ok I did it last week to my 04 headlights. It came out amazing. Pure JDM look. If you just want to know the temp its 350 pre heat oven for a good 15 min then turn it off. Stick the light in for about 10-12 min take it out. Get a small butter knife or somthing flat and thin thats strong and work your way around the edges starting at the corners once you get it open enough you can use your hands to pry it apart. Do it with 2 people so the other person can follow your tracks with a razor cutting the glue. To seal them back up get clear silcone from home depot 3$(aqaurium glue works). Heat both pieces of the lamp up again the same way so the old glue is sticky. Then put your new silicone on top of it . Press it together when tight put 2 quick grip vices on it let it sit at least over night and your all good. My whole set up with removing, painting and sealing took excatly 10 hours.
Old 09-19-2004, 09:38 AM
Sweet!! Your the man, thanks
Should i use a cookie sheet or just put it on the grille?
Old 09-19-2004, 10:54 AM
Beastiek2's Avatar
Banned
Ahh wont matter I through it on the grill just fine. Just keep your eyes on it.
Old 09-19-2004, 01:10 PM
Thanks bro that worked flawlessly. i put it on a cookie sheet though the racks in the oven were to hot and i was afraid they would melt into the light.
Old 09-19-2004, 06:48 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
If you want to play it safe setting it on warm or 200 is better. And leave it in there for about 15 minutes. Do the same to seal it.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 09-19-2004, 06:50 PM
Beastiek2's Avatar
Banned
Such a long process I will never do that again lol. I got the DIY off 7thgencivic.
Old 09-20-2004, 04:32 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
You put the headlights in the oven at leave them in fro around 15 minutes, as said above. I forget the heat temp toset it at (I know 350 degrees was said above). I know I have a link around here somewhere to a DIY that talks about this. If you want I can try to find it and post it if I find it.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 09-20-2004, 08:00 AM
Beastiek2's Avatar
Banned
What I wrote is from the DIY .
Old 09-20-2004, 09:33 AM
and if you read even closer i posted that it worked
Old 09-20-2004, 10:54 AM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
so can we get some pics of what you crazy bas*ards are doing? I've myths about opening the housing and painting the silver part that doesnt reflect, but haven't seen the results. care to share?
word
"Why yes, this is a GS-R."
Old 09-20-2004, 12:58 PM
Beastiek2's Avatar
Banned
This is the final outcome
