Old 09-18-2004, 01:52 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
too much draw?
I currently have one of these amps http://www.cardomain.com/item/POWLT9802
but i need two to move my subs with decent power. I have a 94 integra w/new battery. If i connect another amp to this one will i be drawing to much power?
Old 09-18-2004, 03:20 PM
jncodave jncodave is offline
i think you will be fine hooking 2 of these up. not sure what guage wiring you have and what size fuse but the size of wire and fuse determines how much power you will be taking from the battery, so if you use the same wiring and hook up two amps, you will still be drawing the same power as one amp. hope this helps.
Old 09-18-2004, 03:52 PM
Mannyb18b's Avatar
Re: too much draw?
now when i add this other amp, wut else do i need to do then run the rca's outputs from the other amp into the inputs into the new amp?
Old 09-18-2004, 07:27 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
Re: too much draw?
yes, Output's from one amp to Inputs on the new amp. What kind of subs are they? How do you have them wired?
Old 09-19-2004, 02:22 PM
Mannyb18b's Avatar
Re: too much draw?
alright i found out that i need a distribution block for the power,ground and remote to add another amp.
Old 09-19-2004, 03:51 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: too much draw?
Why did you get a 2 channel amp to start with?
www.cloudcity.deviantart.com
Old 09-20-2004, 02:56 AM
cdawg001 cdawg001 is offline
Re: too much draw?
what amps do you recommend if you hate 2 channel so bad?
Old 09-20-2004, 08:16 AM
Haibane's Avatar
Re: too much draw?
Depends on what the sub's ohm loads are, but I always will go class D for 2 subs
Old 09-20-2004, 09:46 PM
Re: too much draw?
ok if i want 1 15 what amp?
Old 09-20-2004, 09:59 PM
Haibane's Avatar
Re: too much draw?
What is the ohm load? dual 2, dual 4, dual 1, single 4, single 2, single 8, quad 4, quad 2, quad 1?
Old 09-20-2004, 10:17 PM
Re: too much draw?
kicker 15 dual 4
Old 09-20-2004, 10:20 PM
Haibane's Avatar
Re: too much draw?
Get a JBL amp... monoblock, or if it is two, any monoblock really.
