Old 09-18-2004, 01:15 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Question gearing
on a 97 K-1500 350 with 9 inches of lift and 38" tires stock ratio 3.73 what ratio should i switch to to maintain the same power or better?
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 09-27-2004, 05:40 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: gearing
http://4wheelparts.com/4wp/assets/!!!---CHARTS---!!!/chart_gear-ratio.htm
Old 09-28-2004, 09:03 PM
Z71sc's Avatar
Z71sc Z71sc is offline
Re: gearing
The BRETHERN and the MOTHER TRUCKERS UNITE.
This is speaking from owning (4) modified 4x4 and living through the does and should not have's.
One experienced mechanic just told me that rebuilding a rear-end is sometimes more complex than an engine and that he would never do it.
I wanted to do the same thing you do now.
My very experienced mechanic stated this, "If you wish to change the gearing, you must send your rear-end to a rear end specialist who only does rear ends every day, not some 4x4 parts shop who may do a couple a year."
Some are put together too tight, which cuases a vibration, others too loose, just like a doctor, take it to a specialist who does boob jobs everyday.
Old 09-29-2004, 05:12 PM
Re: gearing
There are many regular people who know how to set gears. I've done it in a parking lot before and it still came out near perfect (and it's been nearly a year).
I would think somewhere between 4.10 and 4.88'ish would bring the RPM's back closer to the stock range. You could go even lower if you would like.
