Old 09-18-2004, 11:21 AM
Afrokid's Avatar
Afrokid Afrokid is offline
Send a message via AIM to Afrokid
Evo 5 Front Conversion
I was cruising the web one day, when i found a sick Evo 5 Front Conversion on a 2nd gen Eclipse. I would like to know where i can possible get this done or order it from? Or if anyone else has this body mod done to their eclipse?
Pics here: http://www.cardomain.com/memberpage/425615
"Cant you see that your smothering me, holding too tightly, afraid to loose control cause everything that you thought i would be, is falling apart..right in front of you....every step that i take is another mistake to you, and every second i waste is more then i can take"
Old 09-18-2004, 09:17 PM
george536's Avatar
george536 george536 is offline
Re: Evo 5 Front Conversion
man thats ugly, dont do it. your juss messin up the look of the car.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
