Old 09-18-2004, 10:30 AM
bestoil bestoil is offline
Exclamation orbII codes 2500HD
have codes showing on my 2500HD 01 PO141, 161, 300, 440 any help with what to fix would be great thanks
Old 09-23-2004, 08:34 PM
John Kanaly John Kanaly is offline
Send a message via AIM to John Kanaly
Re: orbII codes 2500HD
po141 = HO2S Heater Circuit Sensor2 Heated oxygen sensors use time to tell if working or not eng not reaching temp fast enuff may set this or bad sensor.
PO161 = ?
PO300 = Engine missfire detected
PO440 = EVAP system fail can be caused by leaving the gas cap lose or a leak in the system
good luck I dont see any one thing to cause all these at the same time.
