Old 09-18-2004, 10:52 AM
jway83 jway83 is offline
Talking got a free rs the other day
my boss got a short notice transfer and gave me his blown engine 96 RS eclipse. now i'm considering doing a 4g63 turbo swap if i don't just sell the car. i only want to spend a few hundred on the swap, so does anyone know where to look? i've already looked on ebay and junkyarddog.com. the junkyard is the pricier spot. also, anything i should know about this car, like recalls and stuff before i get it running? thanks
also, what it the engine code? i know it's a 2.0L I4
Old 09-18-2004, 11:19 AM
wuman82 wuman82 is offline
If you have an RS and want to do a 4G63 conversion it is going to cost you wayyyy more than a few hundred bucks. First the the engine itself is going to cost you a lot. Then its not as simple as dropping the engine in, you have you make new motor mounts, chage the transmission and a lot of other stuff. So yea, its going to be more than few hundred dollars, otherwise there would be a hell of a lot of people doing the conversion.
Old 09-18-2004, 11:21 AM
Re: got a free rs the other day
hmmm. maybe i'll just sell it then
Old 09-18-2004, 11:40 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
the motor code is 420a its the 4cylinder motor in 2g nt eclipses/talons it also in dodge/plymouth neons and stratus/breeze. just put in a 420a then sell it
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-18-2004, 12:02 PM
what year neons is it in?
Old 09-18-2004, 02:09 PM
bclipse bclipse is offline
Any Neons sport or R/T neons
95 GS-T
'cause everyone thinks they're right, and nobody thinks that there just might
be more than one road to our final destination
Old 09-18-2004, 09:42 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
just as a note though, you can't use a neon engine to swap in as it faces the wrong way, if you find a 2.0L Avenger or Sebring, you can use that engine though.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-19-2004, 12:23 AM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
well isnt the block the same? im pretty sure they just reversed the head so shouldnt a neon block work?
edit- if your heads still good to use again that is..
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-19-2004, 01:18 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
i'll give ya 100 bucks for it! cause thats about all she is worth
Old 09-19-2004, 03:24 AM
george536's Avatar
george536 george536 is offline
ill give you 101 and some skittles
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 09-19-2004, 03:25 AM
ill match the 101 and bump skittles upto king size...
AR 15" Baja's
K&N FIPK
Old 09-19-2004, 03:44 AM
ec437's Avatar
ec437 ec437 is offline
I got $98 in quarters here...
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 09-19-2004, 05:57 PM
actually i checked kbb.com and they say it's worth $4400 they way it is. the king size skittles do sound good though
Old 09-19-2004, 06:02 PM
EclipseRST's Avatar
Banned
LMFAO!!! a RS with a blown motor worth $4400
there is no way. its worse than poor condition!
Old 09-20-2004, 09:36 AM
dayna240sx's Avatar
dayna240sx dayna240sx is offline
Banned
Send a message via AIM to dayna240sx
Re: Re: got a free rs the other day
Just a note... usually KBB gives quotes on how much the car is worth when it runs...
