Old 09-18-2004, 01:52 AM
EGcivicSi's Avatar
EGcivicSi EGcivicSi is offline
Headlight Actin Up..
I dont know if it has anything to do with my subs, it shouldnt, but sometimes my right headlight will GO OUT, not dim, but go out and then come back on like a few seconds later. It only happens on low beam and on high I havent seen it happen. Any suggestions on what could be the source?
95 Civic Si
00 Yamaha R6
Old 09-18-2004, 07:08 AM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
Re: Headlight Actin Up..
Deffinitly check all the wires connecting the headlight. It cant be the fuse. And if its only one headlight, has to be wires somewhere, a short. See what happens if you run the car with out the fuse to the subs one day at night 2 see if problem still happens just incase.
Old 09-18-2004, 01:16 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Maybe your low beam bulb is going. Try swapping both low beam bulbs with each other and see if that bulb does it on the other side. If it does, then u should replace it. If not and the other bulb starts acting up on the same side, then it's your wiring.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 09-18-2004, 05:38 PM
EGcivicSi's Avatar
Thanks ill check the harness. I just replaced the bulbs like 2 weeks ago so I dont think its that.
95 Civic Si
00 Yamaha R6
Old 09-20-2004, 05:15 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
By chance, do you have projector headlights? I have noticed that with some projecters the wiring/connectors kind of seems to come loose go bad, realy not sure, but the light will go out, and when you kinda smack the housing from the backsideit comes back on...I don't know if you have projecters. but if you do, thats a thought as to what it might be.
I definatly think it's something in the wiring though. It only does it on right side, so swap the bulb from the left side in. If it does it with that bulb, you can pretty much figure it's the wiring and/or connector. Just reading the post though, I am guessing it's wiring. If you have projectors, that more than likly it, especially if it's they're Sonar (gen 3 is a sonar brand) projectors. I hear of all sorts of problems all the time with that brand.
I hope this was of some sort of help to you.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
