Old 09-18-2004, 01:31 AM
SuperDeck SuperDeck is offline
Exclamation Engine Help
I just wanted to know what parts i would need for a engine. What i mean by that is that im going to buy a b18c block as my project for my civic and i just wanted the parts list of everything i would need for the engine to work. Plz give me a list of parts needed.
Old 09-18-2004, 03:27 PM
wongb18c's Avatar
wongb18c wongb18c is offline
Re: Engine Help
Lol, I'm planning on doing a b18c swap too... just buy the motor stock if you're not sure. Then do a lot of reading that's what I'm doing. I feel the same way I just got a civic hb, and I'm clueless... I want to be apart of the honda world but I don't know where to start.... so I figure I save up for a type R swap. Once I get it I have a few experienced friends that hopefully will help me put it in and give me some advice. It if was up to myself.... I don't even know how a motor works... =p.
Old 09-18-2004, 03:49 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Engine Help
I'm assuming you're talking about the GSR motor, if you're not then let me know. You'll need mounts, shiftlinkage, ecu (with the same OBD as your car is would be easiest), tranny, axles, intake manifold, exhaust manifold, new radiator hose to fit the bigger end of the motor to the smaller end of your stock radiator. And then everything that's a part of the motor itself like fuel rail, alternator, starter, distributor, sensors, plugs, clutch, flywheel, etc.
With the OBD thing, it'd be easiest to get the '94-'96 motor because it's OBD1; the same OBD as your '95 civic. With that the only thing you'll have to do is run wires for vtec, knock sensor, and the secondary butterfly. Here's a pinout for the ECU where all the wires will go: http://technet.ff-squad.com/ Scroll down to the "ECU & Wiring Tech" part and click on the "OBD-1 pinout diagram"
Old 09-18-2004, 09:20 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Engine Help
Just the block or the WHOLE motor? What motor do you have now?
