Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-18-2004, 02:15 AM
lsv601 lsv601 is offline
ecu modules
i just bought an ecu mod off ebay. i was just wondering if anyone knew anything about them. if they work? it says 15-20 hp. will it hurt my motor? supposed to lie to the ecu about the a2f ratio.
Old 09-18-2004, 03:15 PM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: ecu modules
sorry to say - waste of money.
It is simply a $0.10 resistor the you shove in to the AIT sensor to fool the PCM to thinking that the outside temperature is cooler - therefore dumping more fuel in. You can make the same thing yourself by placing your AIT sensor into the freezer until it get to about 40 degrees and then measure its resistance.
THe problem is that the PCM will adjust the change out after a couple of drives.....
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 09-18-2004, 03:45 PM
el es's Avatar
el es el es is offline
Re: ecu modules
I have often wondered what was up wit those gimmicks. Thanks for posting.
