Old 09-17-2004, 08:10 PM
superXracing superXracing is offline
noisy rear diff, recommendations
Hi all, just picked up a 95 Talon TSi. It was a 1 owner non-modded car, but I don't know how great the maintenance was either. The faster you go the LOUDER the rear gets.
What do I need to service or replace? TIA!!
Old 09-17-2004, 08:12 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: noisy rear diff, recommendations
check the fluid level first. if its full try pulling the cover cleaning it out and changing the fluid
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-17-2004, 08:16 PM
Thanks for the quick reply. I'm not too far from you (Chambersburg PA area) I'll check that out. The car seems pretty solid other than the driveline noise.
Old 09-17-2004, 09:59 PM
kjewer1 kjewer1 is offline
AF - Advisor
ITs very very rare for rear ends to fail. I have only heard of one, on a low 11 second car. More likely are rear wheel bearings or axles/CV joints, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-21-2004, 10:21 PM
Put the car on the lift today, gear oil level was fine. Had mechanic friend look over it quickly and he couldn't determine the source of the sound. The rear wheels spin freely and quietly.
The sound gets louder the faster you go and seems to come from the rear center of the car. Anymore ideas?
Old 09-21-2004, 10:40 PM
AF - Advisor
Its hard to tell when modern wheelbearings are bad. They develope very little play, and can seem fine when turning by hand. A far cry from the older wheel bearings If it was my car I would start there, but this is something that is very hard to diagnose over the internet.
Kevin Jewer
Old 09-21-2004, 10:44 PM
Thanks. I agree, it's tough to diagnose without seeing it. I'll start there. Wheel bearings cheap for 2g's?
Old 09-21-2004, 10:57 PM
AF - Advisor
The fronts were 90 a piece from the dealer, I think I had a discount through my brother there at the time as well. Not sure about rears. IF they are bad though, they have to be replaced for safety reasons. Not quite cheap enough though to try out just to see if that fixes it I guess
Kevin Jewer
