Old 09-17-2004, 07:32 PM
starla3366 starla3366 is offline
Send a message via Yahoo to starla3366
Under Hood Crying?
2000 Blazer LT63k While the engine is running I have a quiet WHINING. It's not that loud and it does not get any louder with rpm change. It's not the belt either. From the sounds of it, it almost sounds like a bad bearing in the alternator or A/C motor. I can't pin point it out either. I've checked for vaccum leaks also and none located. Any help would be appriciated.
2000 Blazer LT
4.3 vortec
75k miles
K & N FIPK
Old 09-18-2004, 07:34 PM
tom3 tom3 is offline
Re: Under Hood Crying?
Take the belt off and start it up for a few seconds. If the sound is still there it's not a bearing on the acc. drives. If gone try turning each pulley by hand and listen and feel for a bad bearing. Not uncommon for an idler or alternator bearing to go out.
Old 09-19-2004, 10:04 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
If it is the alternator or the A/C or power steering, it will change with rpms.
Old 09-19-2004, 11:58 AM
Mikado14 Mikado14 is offline
.......And so will the idler pulley and the tensioner pulley
Old 09-19-2004, 12:26 PM
BlazerLT's Avatar
AF -Advisor
More than likely, a whining sound is usually from the alternator on a 4.3L.
It was on mine.
Old 09-22-2004, 08:40 PM
sinzn0more sinzn0more is offline
Send a message via Yahoo to sinzn0more
mine did the same i replaced the belt and idle pulley but that didn't help
I had to change the water pump a few months later and what do you know the thing quit whinning
Good Luck
