Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-17-2004, 07:16 PM
jojodanca jojodanca is offline
Send a message via AIM to jojodanca
Question b16a1 swap question
I have a 1990 civic hatch DX and i am getting a b16a1 from a 88-91 civic SiR will the motor mounts from the SiR work on my civic or do i have to buy different mounts
Old 09-17-2004, 08:01 PM
89civichbracer 89civichbracer is offline
To swap the b16 into the 88-91 civics the right way, you need to get after market motor mounts. There is away to use the other mounts jdm and or us, But You need to cut and weld the mount brackets on the car and the car i have seen this done on, The motor sits wrong and in the long run will cost more money time and effort then its worth. I use the hasport mounts on my swap and have had not problems but any aftermaket mount will work.
I got a deal on my nount thru the company i order my motor thru you might want to look it to that. There are also other aftermarket items you will need to complete the swap the right way, like the shiftlinkage
wich can be cut and welded but shifting will be sloppy.
let me know if you need any other info
Old 09-18-2004, 07:24 AM
Re: b16a1 swap question
thnx for the info yea i have everything but the mounts the swap i bought has everything like harness ecu linkage tranny and a bunch of other stuff but i must ask if it comes out of a 88-91 civic SiR wat makes the mounts different
Old 09-18-2004, 11:30 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Re: b16a1 swap question
Its angled differently. The wiring harness needs to be customed. Everything is opposite since it came from a RHD car. go here www.hasport.com
Old 09-19-2004, 08:01 AM
thnx for the info i ordered the mounts last night 9/18/04 but the swap comes with every thing else to put it in so now im just waitin for it to get here if i have anymore ?'s i will deffanetly ask you guys/girls are very helpful
Old 09-19-2004, 12:07 PM
mellowboy's Avatar
We're here to help
