Old 09-17-2004, 06:20 PM
Future303 Future303 is offline
Guys help!! Shocks/struts!
Ok, I'm replacing the Shocks/Struts in my '95 GT. I notice these little damper shocks above the struts and I need to replace these also. Where can I buy these things? I've been looking all over the place and nobody carries them!
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 09-17-2004, 06:32 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
are you talking about the quad shocks attatched to the rear axle, right behind the top of each rear tire? there's really no need for those... but if you really do need them they can be had at www.50resto.com.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 09-17-2004, 06:36 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Actually unless you've changed gears, you'll notice a good amount of wheel hop under full throttle w/o them. I had a hell of a time trying to find them myself. I know steeda carries some for a decent price.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 09-17-2004, 07:16 PM
that being the case, mine will come off when i change to 3.73 and rebuild my rear axle.
-Andy
Old 09-17-2004, 09:33 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Guys help!! Shocks/struts!
NOOOOOOO, even with gears the quad shocks will help. They are there to dampen the twist of the axle that creates wheel hop. This happens when torque is applied though the stock rubber bushings and flimsy stock control arms. Gears will multiply this and can even make the axle hop worse.
Really the quad shocks can be removed if after-market control arms and installed with better bushings. This comes from first hand experience. I had major wheel hop when I installed my 3.73 rear over the 2.73 rear. Once I replaced the control arms, the wheel hop was just about non existent.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 09-17-2004, 09:37 PM
wildstringer's Avatar
wildstringer wildstringer is offline
ok , let me get this right if i go with aftermarket control arms , which i plan to do , i can take the dampener shocks off . mine look like some one beat them at one time for tire clearance. sorry to more in on your thread man but while we are at it i was looking at the summit brand control arm set any preferences
"If the devil danced in empty pockets, He'd have a ball in mine "
87 LX 5.0 - I'm not even going to say what I've done to the car cause when I see how much more I want to do I wanna cry.
Old 09-17-2004, 10:04 PM
andrewespo's Avatar
andrewespo andrewespo is offline
What is wheel hop exactly?
Old 09-17-2004, 10:40 PM
t5hat is when you take off from a stop and instead of the tires staying firmly on the ground they will bounce or "hop"
Old 09-17-2004, 11:19 PM
Re: Re: Guys help!! Shocks/struts!
ugh, thanks for clearing that up! coulda screwed myself over. do you have to replace the uppers and lowers at the same time to avaoid wheelhop?
-Andy
Old 09-18-2004, 01:01 AM
I believe that's what it does.
Anyway, are quad shocks from a 93 compatible with a 95? Thanks.
Old 09-18-2004, 02:19 AM
Sorry I wasnt thinking staight earlier. I meant control arms, not gears!
Old 09-19-2004, 12:29 AM
Guys, does somebody know if the Quad Shock Dampers from a '93 Mustang are compatible with a '95 Mustang? Someone is selling me a pair cheap, and they look exactly the same, but before I buy them I'd like to know so I don't end up with useless shocks.
Thanks.
Old 09-19-2004, 12:32 AM
if it smells like a duck, looks like a duck, and quacks like a duck, it must be a duck =P
i'm not sure if that's a chance i'd take, but if they look identical i'd say go for it and see if they work...
-Andy
