Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 09-17-2004, 05:35 PM
eclipseb0y eclipseb0y is offline
Question smoke out the A$$?
First, thanks for the help with my fairlady z with the recent problems, my friend just got a 90 300zxTT the other day and like me hes no mechanic, he bought the car for $3500 with only 106,000 kmi, not bad, i noticed when i was behind him, he tryed to lose me letting his turbos spool and when he shifted, black smoke came out the pipes, could this be a broken seal on a turbo or just a leak?...what do you guys think?
Old 09-17-2004, 09:03 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
If the smoke appeared only when he shifted and wasn't that bad, then its just normal engine wear on the piston rings, which keep the exploding gases inside the cylinder and out of the crank case. If you see a steady stream of black smoke, shifting or not, and its pretty bad, then that is just normal engine wear as well, just alot more of it. Also, when you shift and let off the gas, your air fuel ratio is temporarily screwed up. Suddenly there is a hell of alot less air coming in then the engine thought but the fuel for that air has already been metered out, and the engine runs slightly rich for a second. Thats nothing to worry about, just part of how cars work. Its more common with turbo engines as they are burning more fuel.
Long story short: As long as there wasn't alot of smoke and it only shows up when hes on the throttle hard and shifts, then there probably isn't anything to worry about.
And I would like to know exactly where the hell you buy a TT Z32 for 3500.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 09-18-2004, 12:16 AM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: smoke out the A$$?
i would like to know that too. where do you find a TT for 100k miles for only $3500? i don't even think you could find a running TT for $3500.
ZedEx Crew Member #2
Old 09-18-2004, 01:18 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
shit u can barely get the front clip for $3500. whatever it was, that was a hell of a deal.
ZedEx Crew Member #4
