Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-17-2004, 01:36 PM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
4WD HI jumping out of gear
Anyone heard of this?
My 98 Rodeo with automatic trany when in 4WD HI sometimes jumps out of gear like it is trying to switch to 4 WD low on it's own. Not sure what would cause this, hoping that some one here can help. Sounds horrible when it happens and I must come to a complete and quick stop in torder to get it back into gear.
Old 09-17-2004, 11:17 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: 4WD HI jumping out of gear
measure the cicumfrence of your front and rear tires if front worn more or rear worn more this can be your problem
Old 09-18-2004, 09:39 AM
rodeo02 rodeo02 is offline
Yes- like 2eye says, different sized tires will cause driveline bind, which can pop the xfer case out of range. Same EXACT sized tires all the way around are a must on these 4x4's. Dont drive it on dry pavement in 4x4 too long if you can avoid it.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 09-18-2004, 08:08 PM
86TATpi 86TATpi is offline
If tires are the right size you may have a problem with the syncronizer ring cracked, or another problem in the transfer case.
Old 09-20-2004, 07:53 AM
Thanks guys. Looks like tires are my problem. When I purchased this thing a couple of months ago it had 2 new tires on it, and the other 2 were pretty old and worn but with tread still on them. Looks like I am tire shopping. I was hoping it was something simple. Thanks again.
