Need some help please:
- How to remove the front wheel hub to replace a broken wheel stud? - Are the square plastic protrusions on the back of the instrument cluster the instrument lights? Two are out ,need to replace ( turn them or pull them out?) Thanks Last edited by Raljs; 09-17-2004 at 02:03 PM. |
Re: Caravan
I have replacd broken wheel studs on the Caravan before - you don't need to remove the wheel hub. Try rotating the hub, there is a spot next to the struts where there's just enough room to remove and replace the studs. You may need to hammer/punch the old ones out. Once the new ones go in, seat them by tightening the lug nut on them.
Also, the plastic pieces on the instrument cluster hold the light bulbs. They twist about 1/4 turn and pull out. |
