Old 09-17-2004, 12:11 PM
stlwagon stlwagon is offline
Pulley Swap Problems
Any one else experienced this? Was swapping my stock press-on SC pulley yesterday using my Pulley Boys puller. Pulley popped and came off ok, but the 8mm stud sheared off in the SC shaft and the pulley tool. Took me an hour to get the broken pieces out of each using a a dremel to create a friction point that would take a small screwdriver. Was surprised how little it took to break that stud.
On a happier note, new pulley went on with no problems.
Old 09-17-2004, 12:32 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Pulley Swap Problems
Didn't have any trouble with mine. I installed a 3.4" from Thrasher. Poped right off. The fun part was the air box. The information they send is really messed up. Oh wait, that was me.
Old 09-17-2004, 12:35 PM
BIG-L's Avatar
BIG-L BIG-L is offline
I have done about 6 swaps with mine and still using the same bolts and stud,but I do have an extra set just incase....did you use lots of Anti-sieze,I goop the crap out of them...ive read where others have had that problem and most think its because there was not enough Anti-sieze on it and the heat has something to do with it on the small M-8 stud.Just a thought!
~Larry~
ClubGP Member 6530
Since 2001
Old 09-17-2004, 12:42 PM
I slathered everything with anti-seize. Maybe I had a defective stud. At least I was able to get the broken pieces out.
Old 09-19-2004, 02:21 PM
JoeJoe231455 JoeJoe231455 is offline
It is actually pretty common to break them. Your putting alot of pressure on that little thing. At least you didnt strip your snout like I did turning it the wrong way.
<---total tard
2001 Pontiac Grand Prix GTP
1994 Pontiac Firebird Formula
1972 Pontiac GTO
Old 09-19-2004, 03:28 PM
I guess things turned out ok considering. One last thing. Since I swapped the pulley I'm now noticing a constant chirp from the SC belt. I had installed a new gatorback (4060660) before the pulley swap (about a month ago). Would using the belt with the stock pulley ruin it for the 3.4? Should I replace it again? Thoughts?
Old 09-19-2004, 03:29 PM
Or should I go with a larger tensioner pulley?
