Old 09-17-2004, 11:09 AM
osok_deadeye_21 osok_deadeye_21 is offline
Driver Door problems Help!!!
Ok I am having a problem with my driver side door. Whenever I unlock it with my keyless entry the door handle sticks and wont open. Anyone else every have this problem? And how do i fix it? I had to lock and unlock the door and time it just right to open the door its getting old fast.
Old 09-17-2004, 11:11 AM
Igovert500's Avatar
blue + red light magnet
Re: Driver Door problems Help!!!
Do a search, I think I read something about this before
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-17-2004, 11:42 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
Darn, I had the same problem, I took the door apart like 3 times and it never worked. I wiggled the locking rods, sprayed WD-40, nothing worked! then all of a sudden it fixed itself and has been fine since!
The problem is that the locking solenoid gets stuck and the rod that unbolts the from the outside handle dosent push far enough to unbolt the door lock. if you take the panel off and sit in the car and have someone pull the handle from outside you will see the rod go up and down but never touch the switch, then when you pull the inside handle a different rod pushes on the switch. I made a spacer to fill the gap between the rod and the switch but never got to use it since it fixed itself. try wd-40 if not then fins some hard plactic or rubber and make a spacer.
Old 09-17-2004, 11:55 AM
ok thanks man i will try that
Old 09-19-2004, 10:55 PM
3KGT98 3KGT98 is offline
Send a message via AIM to 3KGT98
Same problem
I sort of had the same problem, except it wouldnt lock when i tryed to lock it with the keyless lock. I took it to an automive shop and they only charged me like 19$ for the part shipping and handling no a big deal really.
Represent
