Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 09-17-2004, 11:12 AM
Fireflynj Fireflynj is offline
'84 4 cyl , RPM drops too slow
what would cause the RPM to drop slow?
when I push the clutch in/let the gas off and shift, I find myself waiting for the RPM to drop so when I let the clutch out it would be a smooth shift and not be wearing my clutch out.
'84 Silver 2M4 SE
Old 09-17-2004, 11:49 AM
GTpaul86 GTpaul86 is offline
Send a message via AIM to GTpaul86
Re: '84 4 cyl , RPM drops too slow
somthing holding the butterfly open in the intake would be my first guess
Old 09-18-2004, 09:24 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
sticky idle air control is possible... faulty map sensor, vacuum leaks are also a possible cuprit. Does it idle smooth? at what rpm is low idle?
You said 2m4 SE, are you sure it's not a 2m6?
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 09-19-2004, 07:06 PM
2M4 2 door, mid engine, 4 cyl
yes I'm sure, it has an Iron Duke
Idle is smooth after it is warmed up, about 800 rpm
when Its cold it does have a problem of rpm dropping and engine stalls
I just tap the gas to keep it from stalling.
Old 09-19-2004, 10:49 PM
I'd check the idle air control motor.
Wanted to buy:
Old 09-19-2004, 10:55 PM
Midnightryder Midnightryder is offline
well every now and then i will start mine in the morning and it stalls on me...put it like this...if u have a 5 speed...let it warm up even in warm air...because when u start shifting...it is a lot smoother if it warms up...
