Old 09-17-2004, 07:23 AM
Daikos Daikos is offline
Connecting Amp
I'm currently in the process of setting up my new subwoofers + amp and being that I am brand new to this have run into a problem. I don't know where to connect the 12v remote turnon/off wire. I know its supposed to connect somewhere to my head unit but I don't know where. I currently have a Pioneer DEH-1600 unit in a 93 eclipse if that helps.
Thanks.
Old 09-17-2004, 08:58 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Connecting Amp
the headunit should have a remote output, use that
it's normally blue with a white stripe
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-17-2004, 01:57 PM
All i'm seeing is the left / right plugins, the wiring harness and a black what i assume to be power wire connecting into it.
Do you mean connect it into the wiring harness where theres a blue with white stripe wire running?
Old 09-17-2004, 02:56 PM
94hondaacc 94hondaacc is offline
Yep Thats The One, But Make Sure Its Not The One For The Power Antenna.
Old 09-17-2004, 03:39 PM
power antenna is running in there currently so is there another one or can i just disconnect power antenna? (my antenna is stationary)
