Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-17-2004, 12:59 AM
kilroy357 kilroy357 is offline
92 bonneville charging system problem
i have a 92 bonneville se and whenever i use the ac and use the regular fan the amp gauge drop almost to the red and stays there sometimes after i turn it off and not long after that the alternator starts to whine and then i have to replace it again, i am starting on my third alternator all ready and i was wondering if anyone had any similar problems or what not..... another thing as far as the facory radio wiring goes i was also wondering if cutting the factory wiring would have any effect on the car, because i bought the car off my brothers girlfriends mom and my brother told me that after they had cut the wires off that some things on the car had changed.This is just a question not important but if you can answer it go on ahead
Old 10-14-2004, 06:46 PM
iceman1 iceman1 is offline
Re: 92 bonneville charging system problem
cutting the factory wires will not have any affect on this unless someone cut some wrong wires and connected them wrong. does your car have a high wattage stereo system? if you have a bad battery and replace your altenator , this will kill your new altenator quickly. check your battery.
Old 10-15-2004, 01:16 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with iceman, sounds like a bad battery or possibly a bad ground or battery cable.
Old 04-16-2005, 07:02 PM
Olszewski Olszewski is offline
Re: Re: 92 bonneville charging system problem
The two small wires just off the alt can break of just be a bad connection there. Repair the wires by slodering them together.
