Old 09-16-2004, 09:16 PM
kobalt kobalt is offline
Unhappy 4t65 problems
Hello all! I recently purchased a 2001 Aurora 3.5, but the overdrive does not want to engage. In "D" at speeds when it is supposed to engage, I hear a dull whine and thats it. Selecting "3" eliminates the whine but no overdrive (of course). The fluid is at the correct level and does not smell burnt. The tranny shifts perfectly - its responsive and smooth. Im thinking torque converter is not locking up and might need replacement. Any ideas?
Old 09-17-2004, 11:32 PM
94sportsedan 94sportsedan is offline
The TC doesn't give you a 4th gear. You may have a bad shift solenoid.
Old 09-18-2004, 10:48 PM
Re: 4t65 problems
Perhaps - it does not seem that the tranny even attempts to shift
Old 12-13-2004, 10:36 AM
2000GPGTBlue2dr 2000GPGTBlue2dr is offline
Lightbulb I have the same problem with my GrandPrix
A good test for overdrive is put the car in 3rd gear. Get up to highway speed (50-60mph), turn on cruise control, and then push the shifter into D. If the car does not change gears (like my car) then the Overdrive is not moving from 3rd to 4th gear.
This site does a good job explaining the Transmission converter clutch.
http://tech.oldsgmail.com/trans_TCC.html
It looks like Overdrive is controlled by the solenoid that gets a signal from the ECM to make the gear shift from 3rd to 4th. There are 2 wires that go to the solenoid- 1 for the 3rd gear and the other for 4th.
