Old 09-16-2004, 08:49 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
C Pillar Install Help
well i have a 90 crx si and the c pillar goes where the 88 crx have there seat belts anyway i can get it to work on my 90 crx????
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 09-17-2004, 03:11 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Huh?
That makes no sense at all... what are you installing?
Old 09-17-2004, 08:06 PM
Re: C Pillar Install Help
simple 88 crx seat beltbrackets are on the c pillar....and the 90 crx brackets are on hte door....and the aftermarket c-pillar bar only can bolt to the cars that came on the c pillar....question is how can i built it to my 90 crx...
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 09-18-2004, 03:34 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
cant you just get a bolt long enough and mount it through the side of the car, the frame of crx couoldnt have changed that much, rip off the plastic around the area and see if there is a place to mount the bar too, then just cut a hole in the plastic so you can slide it through.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-19-2004, 01:12 AM
i already did but that not working for me i take pics and get them on here sense you guys dont see what i am saying
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 09-19-2004, 12:57 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
i know what your sayin - the plastic moldings where the seat belts go on the side go all the way down to the windshield in the front... 90 - 91 have them -where the seat belt goes up the door from on the bottom an click into the latch an then go up to the side of the car behind the seat. But the ones you have only go half way up from the windshield an will obviously leave you with out molding on the back half where the belt bolts into the side of the car on the top.... i would take both piece an line them up pencil a make alittle extra than what needs to be cut then take a utility knife an skim had the end so it slide under the new pillar pod you want to install - then tech. screw the mold into the metal when you have it in the correct position...
Good Luck
Hope That Helps =)
Old 09-23-2004, 01:10 PM
did that help at all ?
Old 09-24-2004, 08:13 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
are trying to install a C-pillar bar? in a CRX?
ok, first off, the place where people put pillar mounted gauges is the A-pillar. the pillar between the door and back half of the car is the B-pillar. and the pillar between the rear side windows and hatch is the C-pillar.
on the civic hatch, its a simple install for the C-pillar bar. just take the rear seatbelts off, and bolt the bar to the those mounting points.
for the CRX its potentially more difficult. i havent ever checked behind the panelling for bolt holes, but i know that some of the JDM CRXs had rear seats in them, so possibly the bolt holes for rear seatbelts exist.
look behind the rear window panelling for bolt holes. if you are trying to install a C-pillar bar on the B-pillar, it may not be long enough, and i know for certain that my 90 hatch didnt have threaded bolt holes on the pillar, because the seatbelts were on the door.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 09-25-2004, 10:57 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
I dont think he has much mechanical skill. or english.
