Old 09-16-2004, 07:05 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
Unhappy My Putty Cracked
Hey everyone. Some of you know that I started up the V-dub GTi project and have loads of thinly applied layers of bondo. Every time I sand it, it has been able to dry and harden for about 10 good hours. However, last night I was wetsandin with 150 and 240 paper and I noticed quite a few hairline cracks. I don't get it. I built some support bars from brass for the inside of the car so nothing is stressed while it's being sanded. So, I've sanded it all down.
Here's my question. Should I strip all the putty off and start over with Tamiya Epoxy Putty? Wait a few more days and apply thinner layers of bondo? Purchase epoxy putty (isn't this like the best damn putty in the world?) and apply that thinly over my bondo and let it dry a day then sand?
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 09-16-2004, 07:21 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: My Putty Cracked
Well, hate to say this but that's what you get for using bondo spot putty. It's not ment for big project's like that. I recommend Bondo Body Filler. Sand that smooth and then the "pin holes" you fill with the spot putty.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 09-16-2004, 08:09 PM
86_SR5's Avatar
Well, I just threw the car in the box and the projects on hold once again. I made the mistake of trying to cut out the doors (hatch was already cut open) and that warped the body, and cracked the hell outta the putty. So, its in the box... maybe in a few years I'll buy another GTi and fix this project back up. Thanks for your reply Josh.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 09-16-2004, 08:44 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I was going to warn you of that when I saw your project completely mudded, but last time I stuck my nose in peoples putty business I got bitched at like crazy.
You need to part putties unless you are filling pin wholes. Otherwise the putties shrink and crack as you've experienced.
-Mike
Old 09-16-2004, 09:08 PM
86_SR5's Avatar
Yea I was waiting for you to say something Mike... why didn't you!? lol Anyway, I'm gona try and get back to work sometime soon, with this stupid left hand, got stung and it swelled up like a baloon. only had time for modelling. Maybe in a couple months, like around December, I might pick up another GTi and start over again, what putty would you suggest, Mike?
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 09-16-2004, 09:52 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I would suggest: Not putty at all. Build it up with plastic - styrene sheet, rod, strip, and whatnot. Use putty only to fill gaps.
Old 09-16-2004, 10:04 PM
86_SR5's Avatar
kinda hard to do when I'm really just widening the fenders and their flares. I could just melt tons on plastic and sand that, but that's just too much work. Thanks for your post though.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 09-17-2004, 02:01 AM
RallyRaider's Avatar
Zomby Woof
Even if all you are doing is widening the fenders you can still use sheet styrene to make a "shelf" around the arch and then fill the gap with putty. Doing so supports the putty which is more brittle and less flexible than styrene. Take a look through some of the work my members like kunta - he as it down to a fine art. Of course you'll need to use two part epoxy putty for such big jobs. Air drying putty will never set.
Old 09-17-2004, 10:20 AM
mike@af's Avatar
Just like Phil and Will said, and then use some Tamiya Epoxy Putty. Dont be worried when it looks like a small amount in the box, it lasts awhile.
-Mike
