Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-16-2004, 06:47 PM
twisted99 twisted99 is offline
? bout broke timing belt 89 SI
Freind of mine broke his timing belt on his 89 SI. What are the chances he didn't bend the valves or damage a piston? I broke mine on an 85 MR2 with no damage, not sure about Hondas Thanks
The only engine failure I've ever had was an Isuzu engine.
Old 09-22-2004, 07:36 PM
Anybody? Please
Old 09-24-2004, 10:13 AM
hondaprelude88 hondaprelude88 is offline
Re: ? bout broke timing belt 89 SI
There is a chance it will just have to be opened up and look at it, you were a lucky on with the mr2 its just chance that when it brakes everythings lined up perfectly, same for any motor.
Old 12-20-2004, 02:10 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
not necessarily... It depends on what type of engine it is... if it is an interferance engine and the timing belt breaks.... you could be in trouble... I have a 90 corolla it is interferance... if that belt breaks... something will probably bust... but I also have a 1995 ford escort... with the 1.9l sohc engine that is a non-interferance engine... the timing belt has broken in this car before... but nothing to worry about...
Old 12-20-2004, 06:34 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
I have broke a timing belt in my previous 3rd gen and it didnt cause any problems. But that doesnt mean anything. You will have to pull it apart to find out friend.
Old 12-20-2004, 07:43 PM
FatAlbert85's Avatar
FatAlbert85 FatAlbert85 is offline
I had an '88 Si that the timing belt broke on, and I had to get a new cylinder head 'cause it bent the valves. Your friend might get lucky though.
P.S. Don't mind the avatar... I still like Hondas, I just drive a Nissan!
*Remember, straights are for fast cars, turns are for fast drivers!*
Old 12-20-2004, 11:09 PM
ludegurl's Avatar
ludegurl ludegurl is offline
YOU NEED TO REMOVE THE CAMSHAFT SO THAT ALL THE VALVE WILL BE CLOSED. THEN DO A COMPRESSION TEST ON ALL CYLINDERS.
IF YOU GET COMPRESSION PRESSURE OF MORE THAN 100 PSI ON ALL CYLINDERS, THAT MEANS ENGINE HAS NO DAMAGE.
Old 12-21-2004, 07:00 AM
sofast's Avatar
Re: Re: ? bout broke timing belt 89 SI
Lookin good Ludegurl. Oh yea the car looks good too.
Old 01-01-2005, 10:26 AM
I can't believe I did not think of that.
THANKS
Old 01-01-2005, 03:10 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
you dont need to remove the camshaft, just turn the motor over till the valves are closed for each piston as you test that cylinder, aslong as the cylinders are within 10% of each other you should be ok...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
