Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-16-2004, 06:12 PM
pitm96 pitm96 is offline
saturn leaks on passenger mat!!!!!!!!!!!
hi i hope someone will be able to help me. i have a 1995 saturn sL1 and the floor is always soaked. i pulled up the carpet and theres water coming from somewhere but i have no idea where. i think it might be from the rain but how would it be getting inside my car. any help would be greatly appreciated. thanks the drip is actuallt coming from underneath the console- maybe the rain drains are clogged or sumthing???
Old 09-16-2004, 06:22 PM
Chris101 Chris101 is offline
I had the same problem and it was resolved after looking at a thread from Saturnfans.com. I guess this is a common problem for a lot of Saturns.
http://www.saturnfans.com/forums/sho...threadid=36267
Old 09-17-2004, 01:32 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: saturn leaks on passenger mat!!!!!!!!!!!
very common, but several things can cause it. that link gives two of the most common problems. they usilly cause the seat to get wet, the carpet being wet may be that or it may be a few other things. try the link first, if it doesn't help, i'll throw a few others out there. do you have A/C?
Old 09-17-2004, 01:30 PM
yea i have a/c- the water is coming from behind the console. either from rain that isnt draining or ac or sumthing. i dont believe its from the doors although they occasionally leak so ill lookinto that. any suggestions?
Old 09-17-2004, 10:35 PM
there is a old TSB on the A/C drain hose leaking, i dig it up on monday.
Old 09-18-2004, 04:43 PM
saturn ac leak
ok ive found the leak- after taking a bunch of things apart. the leak is definatly coming from the Ac. when the water collects all of it isnt draining out of the hose. i think there might be a crack internally or sumthing but its leaking out around the output of the Ac. any ideas on how to rig it so it wont leak. i was thinking maybe caulk it all up and drill my own hole and run my own tube- bad idea?
Old 09-18-2004, 06:51 PM
bad idea, if i remember correctly the clog is easy removed, wait til monday.
Old 09-19-2004, 11:07 AM
ok ill wait
Old 09-21-2004, 12:32 AM
the TSB talks about three places that can leak:
1. sealer skip of the "smile" joint
2. sealer skip at the strut towers
3. past the HVAC case seals
from what you say, its #3.
for #3 the TSB says to use "Kent Industries Chek Spray Water Leak Sealer (P/N 50265) or equivalent, spraying seals with two coats."
i would also check the drain hose and the hole for clogs as in this picture, saturn says to use the eraser end of a pencil, i would use pipe cleaner.
http://files.automotiveforums.com/ga...p?photo=27873&
