Old 09-16-2004, 05:08 PM
steve turner steve turner is offline
Question 1998 chevy metro transmission noise
I just bought a 1998 metro with a 1.3L 5 speed 105,000 miles.While driving down the road and letting off the gas you can here a noise ,like somthing rubbing or a bearing making a grinding noise,when you hit the clutch the noise goes away. When I first test drove it the shift pattern was real stiff so I lubricated the linkage and it fixed that. Thanks for any help on this or any other problem these cars are pron to Steve
Old 09-17-2004, 03:14 PM
mike68 mike68 is offline
my 95 made a growling sound like yours with the clutch out. push the clutch in it would go away mine did it all the time sitting still on the road. it ended up being a bad bearing in the trans these transmissions aren't hard to take apart but definetely not for a novice.
i had trouble with the front seal rolling up when you put the case back together make sure you use a new seal with plenty of petroleum jelly on the input sshaft these seals are very fragile
Old 09-17-2004, 04:27 PM
geozukigti geozukigti is offline
Throwout bearing. Might as well replace the clutch while you're at it. A Metro clutch kit comes with a new throwout bearing. You should be able to do a clutch on the metro in a few hours. If you search the forums, there's directions on how to remove the transmission.
Old 09-17-2004, 05:52 PM
Re: 1998 chevy metro transmission noise
Thanks for your help. While I have it out sould I look at anything inside the transmission? Steve
Old 09-17-2004, 10:15 PM
if its the clucth release bearing it will make noise with the clutch pedal pushed in. the "throwout bearing" should not be turning with the pedal out unless the clutch is adjusted too tight. the clutch fork pulls it away from the clutch disc.
Old 09-25-2004, 09:04 AM
Pulled my tranny ,through out bearing looked ok so I took the tranny apart the big bearing on input shaft had pits in the bearing the small bearing was ok .I purchesed a tranny kit for $165 had all bearings and synchros. Have been driving for two days no noise. THANKS ALL
Old 09-27-2004, 10:38 AM
WOAH! Where'd you get that tranny kit??? That's a sweet price, i'm gonna need one of those for a synchro set soon.
Old 10-03-2004, 02:34 PM
mantrans.com best price I could find. What would be your advice for improving fuel economy ? I thought about water injection
Old 10-04-2004, 09:42 AM
Well, the best way to go about getting better fuel econony is to make the engine more efficient. Better exhaust, better intake, hotter spark, better spark plugs, smooth hubcaps. Water injection would work too, but you run the risk of hydro-lock in the motor.
