Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-16-2004, 02:51 PM
tgenerl tgenerl is offline
Question Transmission feel/sounds (2000 LS)
Hi all,
Please reply with any ideas, thoughts, feedback regarding the following:
Car: Chevy Impala LS 2000 3.8L V6 SFI (43,000 Km)
Had the Transm. fluid topped off during a routine oil change at my mechanic last November 2003...Had the oil changed a few weeks ago and the mecanic said the ATF level was fine...The fuel filter and PCV were also changed...
Everything was fine until 2 weeks ago when I noticed a change in the way shifting (1-2; 2-3...) felt / sounded...Now it feels not as "smooth and gradual" as it used to up until a few weeks ago...Now it's like it "shifts faster" with less smoothness and also there like a kick back (as if someone is pushing or kicking the front"...It is very ANNOYING...It's like a little jerky...It is somewhat audible (not so much a grinding noise)...however a noise nevertheless... :?
Thank you in advance
tgenerl
Old 09-20-2004, 12:01 PM
giantone giantone is offline
Re: Transmission feel/sounds (2000 LS)
tgenerl,
Just put mine in the shop. For a couple of years the transmission has been slipping in the morning or when it was cold/wet. It started acting up after a weekend trip. It would go out of gear while it was in reverse or drive. I jumped from gear to to gear. Before this happened I would hear an occasional whining or whirring noise. For the past three years, when I would put it in park or neutral, the engine would roar louder than if it was in gear. If you are having any of these problems or symptoms, I would have a shop look at it. Each time I took it in, they could find no problem. They found it this time, but I had to lose my transmission first ($3,000 for a factory rebuilt) Mine is same year as yours. Hope you have better luck.
Giantone
Old 09-21-2004, 05:45 PM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
Well i had the same problems with the shifting in reverse and drive and having the hesitation. Then i noticed that if you are driving about 10-15 mph...let of the gas and coasted a little bit....and pushed the gas again the car would slam back into gear. I took it in, they said the transmission needed a "valve job". It was fixed under warranty, the shifting in mine was just like you described. The fix made the shifting smoother but it still does the hesitation in forward and reverse. It's very annoying!!!! Lately is seems that when i push the gas to make it upshift, it either won't upshift or it goes in the wrong gear...it's weird. Mine is a 2000 3.4 also, but i'm sure they have the same tranny.
Has anyone had problems with theirs? What did you do...they where talking about replacing the transmission, but i'm not sure what they are going to do. The dealership has been great to me here.
Mike
Old 09-22-2004, 12:40 PM
Smile
Hi Guys,
Thank you for taking the time to write a reply...
I have decided to take her for GM GoodWrech Service this week...
***GM Goodwrench Automatic Transmission/Transaxle Service***
What the Dealership I bought the car from will do:
Road-test before and after service
Inspect transmission/transaxle for leaks
Replace transmission/transaxle fluid, gasket and filter
Adjust linkage (if required)
Hope it will fix the funky experience ;-)
I'll let you folks know what happens...
Cheers,
TGENERL
Old 09-23-2004, 09:39 PM
Pat_OD's Avatar
Pat_OD Pat_OD is offline
yea i got a 2000 3.4 same as u bermis my car is about to hit 60000 and at about 52000 i had to get a new tranny. My advice is to get the number to the Big Wigs at Chevy and complain ur ass off about the car i've found out that shit flows down pretty fast if u catch my drift. I mean its worth a try u might get a new tranny. Unless its still under warranty
Old 09-26-2004, 04:58 PM
bswanzek bswanzek is offline
Hey tgenerl
My 2000 Impala had shifting problems similar to what you described. Pressure Control Solenoid was the problem. I think it cost about $600 at Chevy dealer to fix.
Old 10-01-2004, 10:58 PM
blmitch11 blmitch11 is offline
I have been experiencing some of the same problems with my vehicle as well. I have a 2000 3.4 also it tends to jerk when i hit certain speeds and i also hear the whinning when i accelerate. I have yet to have anyone look at it...does anyone know if there is a recall for this? If so is there a way to look up recalls for the 2000 model?
Old 10-04-2004, 03:10 PM
JJTS JJTS is offline
Impala Transmission
I was just told that my 2000 Impala with 54K on it needs a new transmission - ouch! Is there a way to complain about this and get a new one paid for? From what I've read here I am not alone.
Old 10-05-2004, 11:02 PM
Re: Impala Transmission
I totally agree with you, if there is a way to complain I want to know because i do have a lot to say...as well
Old 10-11-2004, 02:04 PM
chevellemann chevellemann is offline
I have a 2000 impala LS with 93,000 miles on it and it is start to give me a jolting, kickback type of feel no matter what speed it is at. I think it is the tranny going out slowly, but the dealershiop cannot find anything wrong with it. My car does not have the whining noise of any kind that you other readers complain of. Any suggestions would help before i shell out any $$ for a tranny. other than that the car runs fine.
chevellemann
Old 10-12-2004, 04:33 PM
lakerfan1784 lakerfan1784 is offline
Send a message via AIM to lakerfan1784 Send a message via Yahoo to lakerfan1784
Problem: 00 and 01 Impalas use the sub-standard 4T65E tranny that was famous for self destruction in 97 GM cars with the 3800. take a look at http://myimpalasucks.com
Do sober what you say you will do when you're drunk. that will teach you to keep your mouth shut.
Old 01-17-2005, 11:19 AM
P1811 - Maximum Adapt and Long Shift (GM)
Anyone experiencing these tranny symptoms as described above should take their car to a trusted transmission service/repair shop and ask them to troubleshoot it via the OBD II (OBD-2) diagnostic tool...
This is the error code I got...
So, who wants to purchase GM?
:L
Old 05-23-2005, 12:32 PM
icebox13's Avatar
icebox13 icebox13 is offline
I just started having trouble with my 2001 Impala last week. My Chevy dealer says it needs a new transmission, and is estimating $2600. A local transmission shop says the same thing, but is estimating $1500.
Has anyone had any luck getting GM to fess up to a faulty product? 15 minutes of research on the internet has shown that this is obviously an issue with the late model Impalas.
Old 05-23-2005, 01:48 PM
wojtek00 wojtek00 is offline
I have the same problem with my 2000. I checked to codes and no problem. I would like to replace the pressure control solenoid. Has anyone done this? Hanes has no information about transmission repair. Is it deep in the trans? Do you have to remove the trans to get at it?
Great thanks for any information.
Old 05-23-2005, 07:14 PM
MCO_Death MCO_Death is offline
Send a message via AIM to MCO_Death Send a message via MSN to MCO_Death Send a message via Yahoo to MCO_Death
Common and known problems posted by GM can be fixed under warrenty, otherwise they will leave you SOL. I agree that the non-HD tranny is fairly... weak.
