Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-16-2004, 02:12 PM
firdaus firdaus is offline
Cool TOyota Camry 1996 - Vent Glass
I have a TOYOTA Camry 1996 model and someone broke into my car by breaking the Drivers side Vent Glass on the rear side door.
I am planning to buy a part from the TOYOTA showroom but do not want to pay the exhorbitant service charge.
Does nayone know of a Self Help or some internet resource that would guide me in the installation of the glass.
Any insights would be greatly appreciated.
Old 09-16-2004, 07:16 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: TOyota Camry 1996 - Vent Glass
Not all these steps may be necessary to remove rear quarter glass.
Remove Power Window Switch - Use taped screwdriver to pry out switch.
Remove Inside Handel Bezel - Use taped screwdriver to pry off bezel and pull bezel rearward to remove.
Remove Door Trim:
Remove 4 clips on sides of door panel
Remove two screws - one is behind plastic screw cap
Pry off door trim with taped screwdriver
Pull trim upward to remove - disconnect electrical connector.
Remove Inside Door Handle - Disconnect two links - Remove three screws
Remove Service Hole Cover - (To align door glass, substitute bolt with washer for centering bolt)
Remove Door Glass Run - Pull upward
Remove Rear Door Belt Molding - Pry out clips from edge of weatherstrip and remove molding
Remove Door Cushion
Remove Door Glass Division Bar
Remove Door Glass - Insert shop rag inside panel to prevent scratching glass
Remove Quarter Window Glass with Weatherstrip - Remove by pulling forward.
Assembly is reverse of disassembly
Old 09-16-2004, 07:20 PM
Brian R.'s Avatar
Resident Chemist
Instead of a dealer, have you considered an auto glass shop. They are much cheaper - both parts and labor.
