Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 09-16-2004, 01:22 PM
jamie390 jamie390 is offline
Removing ignition switch on 2002 ford focus...
Hi, need to remove ignition switch on my 2002 ford focus.Ignition switch is froze up. Does this require taking off steering wheel? And if so, do i need to disarm the air bag? Please help! Thanks James
Old 09-20-2004, 03:43 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
are you removing the switch or the key cyl. ?
-=-=-DANE-=-=-
Old 09-22-2004, 09:24 AM
The key cylinder actually. I did get it to turn, but can't find the removal button to pull it out.
Old 09-22-2004, 08:27 PM
Re: Removing ignition switch on 2002 ford focus...
remove the upper and lower column shrouds to gain access - remove the pats trasceiver that mounts around the cylinder and the release button will be exposed
-=-=-DANE-=-=-
Old 02-04-2005, 12:37 AM
focusboricua focusboricua is offline
Re: Re: Removing ignition switch on 2002 ford focus...
I have a 2000 ZX3 and I also need to remove and replace the ignition switch cylinder. I removed the top and bottom covers aound the steering column and the pats trasceiver that mounts around the cylinder. I tried pushing in the release button but it was not going all the way in and was not able to pull out the cylinder. Do you know or have any info on the procedures needed to remove the cylinder. If you do I'll be greatly appreciated.
Thanks,
José A. Malavé
Old 02-05-2005, 05:33 PM
while pushing the release button - turn the key to the on position - this should allow the button to move all the way in.
-=-=-DANE-=-=-
