Old 09-16-2004, 08:54 AM
trojancouch68 trojancouch68 is offline
Question 99 grand am 2.4l rocking back and forward in idle
when sitting in idle, the car will start to rock back and forward. i just recently had problems with the car misfiring so the mechanic replaced spark plug connecters, but the car still rocks back and forward and makes a nice low pitch noise out of the exhaust, almost like its a muscle car, dunno if that has anything to do with the rocking.
Could it be the spark plugs, or maybe even the idle sensor???
i am lost confused, need help big time!!!!
Old 01-11-2005, 11:53 AM
JT4721 JT4721 is offline
rocking back and forth and high pitch in exhause
i had the same symptoms and it was my fuel pump once replaced it all was gone
Old 01-11-2005, 05:04 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: 99 grand am 2.4l rocking back and forward in idle
What kind of engine? Quad4 misfiring usually the problem is the Ignition Coil Housing. If not the ignition coils and then the ICM.
IDLE is controlled by IAC (Idle Air Control solenoid) which is located on the throttle body. Try cleaning the IAC and the spot where the IAC goes in and test it. The IAC might be bad.
If you have not replaced the fuel filter for a long time then it might be time to replace it and test.
Old 01-12-2005, 09:05 AM
jrgong jrgong is offline
Send a message via AIM to jrgong
Hey i might be able to help you out... I drive a 99 Olds Alero with the 3.4
Once you start driving, does the bucking go away?
This just happened to me the other day...when i was idling, it would begin to buck back and forth, and the rpm's would jump from 500-750 and fluctuate around...
I took it in, and they said I had a slplit line leading into my intake.... After the diagnostic, parts, and labor, it was $85 to fix, and I havent had the problem come back yet... however, im not sure what the diag code for it was
hope this helps
jr. Gong
