Old 09-16-2004, 08:08 AM
turbobrut turbobrut is offline
A/C Low Pressure Cutout
Does annyone know if the A/C system has to be evacuated to replace the low pressure cutout switch that is mounted in the accumulator? The compressor works if I short out the switch leads and the system is not low on refrigerant. I assume the switch is bad. Thanks in advance.
Old 09-16-2004, 08:26 AM
Sfrid073 Sfrid073 is offline
I was able to replace mine without evacuating. It should just be on there handtight. I just unscrewed it. I'm guessing its a one way valve on it. It hissed just for a second when taking it off.
Old 09-16-2004, 09:07 AM
Mikado14 Mikado14 is offline
Re: A/C Low Pressure Cutout
It's a crapshoot. The low pressure switch mounting point normally has schrader valve in it. Removal of the switch can be done without evacuation. However, if it has been changed from OEM to an aftermarket, it may or may not have the schrader.
Old 09-16-2004, 10:39 AM
thanks a lot for the information.
Old 09-16-2004, 10:40 AM
Re: Re: A/C Low Pressure Cutout
Thanks a lot for the information.
