Old 09-16-2004, 12:07 AM
coolguycooz coolguycooz is offline
What spark plugs to use
Ok i just got an MSD coil pack and magnecore wires. What brand of spark plug should i use that would work best with those? any body recommend anything please?
Old 09-16-2004, 08:54 AM
Juggalo Juggalo is offline
Re: What spark plugs to use
ngk
Old 09-16-2004, 09:19 AM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-16-2004, 09:23 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
yep NGK is what i hear too. whats wrong with Bosch though?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 09-16-2004, 12:29 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
NGK BPR6ES if stock, 7ES if modified.
Old 09-16-2004, 02:13 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Platinum is a shitty conductor, copper a shit load better. Platinum is supposed to last longer, however I had them in my car for a while and after 2-3k miles they started misfiring. Bosch and DSM just don't go together
For Sale 98 Eclipse GS, 5 spd
Old 09-16-2004, 04:08 PM
GSTRacerNVUS GSTRacerNVUS is offline
I guess that would depend on whether it was turbo or not... I think. Cause, the turbo eclipse requires colder spark plugs. I'm not too sure about non turbo.
Is NGK a colder spark plug?
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 09-16-2004, 04:31 PM
ashah000's Avatar
The brand has noting to do with colder and hotter plugs, each brand has its own range of plugs that are colder and hotter. For example NGK does it like this:
NGK BPR6ES
The 6 is what heat range the plug is..
If you goto 7 it will be colder
If you goto 5 it will be hotter
Old 09-16-2004, 04:53 PM
MrZ's Avatar
MrZ MrZ is offline
I can tell you that Bosch platinum plugs run fine in a non turbo 1G DSM, no reason they won't run well in a 2G. I'm using the multi-tip, which are Bosch's best. My first set lasted over 100,000 miles and could have gone longer. I've never had a problem with misfiring, at least not due to the plugs.
Mark
Old 09-16-2004, 06:07 PM
ashah000's Avatar
Well I have had a bad experience with Bosch and I know others have also. NGK's are a LOT cheaper, I usually change them every oil change to every other oil change.
Old 09-16-2004, 06:31 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
ngk iridiums
Don't act like you don't love it.
503/2000
Old 09-16-2004, 07:06 PM
10.5sec92AWDTALON 10.5sec92AWDTALON is offline
No platium 100,000 miles for turbos. Bad JUJU.
NGK Irridium.
Old 09-16-2004, 09:35 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
I have the NGK R's and they seem pretty good... gonna try the bpr7es soon... I tried to get bosch platinum 4's but they don't allow the plug boot to snap in... from the "seat" to the top of plug isn't long enough for plug wire boot!!! I tried the platinum and it ran shittier than the old ngk-r's that came in car when I bought it!!!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 09-16-2004, 11:11 PM
wait so i should just use NGK's for my Non turbo? And get them at auto zone right are there different types? Also what size wrench for the spark plugs cause i forgot
Old 09-16-2004, 11:13 PM
Also i heared that single tip is still the best those multi tip and tripple and the new 4 tip spark plugs all suck is this true?
