Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 09-15-2004, 07:48 PM
804jim 804jim is offline
Question Steering/Key ect Total Lockdown
My 1995 540i is totally locked down. I can't get the key to move in the ignition and the steering is totally locked in place with no play. The only things working are the security system, interior lights and the locks.
Even the headlights will not come on. Emergency warning lights work too.
The last time we were in the car my seven year old yanked the steering wheel as I was turning off the car and removing the key.
If he damaged the steering so that I can't get the key to turn would you expect these type of symptoms? Is it something I can easily fix or do I need to have it towed to the dealer?
Could it be something else?
Is this how the drive away theft protection works? Other potential problems? Many thanks in advance.
Old 09-15-2004, 08:35 PM
Antiburn's Avatar
Antiburn Antiburn is offline
Send a message via AIM to Antiburn
Re: Steering/Key ect Total Lockdown
Try turning the wheel and holding it while your try to turn the key. There is a system designed when the steering wheel is locked and the car is off you cant turn the ignition. Many cars have it.
Old 09-15-2004, 09:21 PM
The steering wheel will not budge. It is locked tightly in place. The wheels are turned at a slight angle and the steering wheel is 180 degree from straight ahead.
Old 09-16-2004, 10:02 AM
I was able to get around the problem by disconnecting the battery for an hour to cut power. Seems like it was part of the security system and cutting power reset the system.
Old 09-16-2004, 09:40 PM
jeffreyb4me jeffreyb4me is offline
Have the ignition/steering lock replaced while you can still drive it [ as apossed to having it towed ].
The locks wear and break causing what you experienced [ has NOTHING to do with the electricals or security system ] or it may get to a point where you won't be able to turn the ignition off.
Old 09-16-2004, 10:50 PM
crash8168's Avatar
crash8168 crash8168 is offline
You will have to exert enough force to the steering wheel to unload the lock mechanism while turning the key.
Old 09-17-2004, 07:33 PM
Just a note, the E36 & E39's do use the same steering lock and I've had many towed in for replacement,.......just a note.
