Old 09-15-2004, 06:15 PM
cbell77 cbell77 is offline
Help with cold air intake
I just got my cold air intake in today and i was wondering what this piece is. it looks like another spot to hook up a breather. i will give ling to pic i just got hosted.
1966 mustang for sale asking $7900 call 757-766-3702
Old 09-15-2004, 06:16 PM
george536's Avatar
george536 george536 is offline
Re: Help with cold air intake
that is not the actual photo of the intake. they juss put the same one over and over sometimes. and if it is the actual picture......... u got the wrong one.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 09-15-2004, 06:18 PM
nope i got that one with that wierd thing sticking out of the pipe that i have no idea of what it hooks up to
Old 09-15-2004, 06:24 PM
george536's Avatar
oh well best thing is return it. or juss close it up with a plug. it wont do no harm. did it fit correctly in your car?
-1990 Eclipse GSX
Old 09-15-2004, 06:27 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
That goes to the valve cover, there is a rubber pipe that connects to the intake and VC. You do not need to use it, I plugged both holes with breathers
Edit>> Or not, does that long pipe connect to the smaller one, so that would make that hole on the long pipe closer to the front of the car?
For Sale 98 Eclipse GS, 5 spd
Old 09-15-2004, 06:35 PM
george536's Avatar
yea one of them goes to the valve cover but theres 2.
-1990 Eclipse GSX
Old 09-15-2004, 06:37 PM
it fits in the car perfectly but the smaller pipe that ccame with the kit had a whole in it that went to the the breather wich was hocked up with small blue hose in picture but the ohter whole in the bigger pipe has nothing to hook up to maybe ishould just plug it up or not i dont know need help tho i want to install it tommorw. I took it out of my car after i noticed that that whole had nothing to hook up to so i know thw intake will fit just fine but i was afraid dirt and other stuff would go into the whole causing problems.
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
hey ashah you should plug the hole on the pipe since its after the mas. with a breather it just lets in air that the mas cant track
cbell i bet its a hydrolock protection thing if it isnt i can tell you how to make it one. just put a small breather filter on it and since its up higher for your intake to suck in water it would have tio have water all the way up over that hole. kinda like trying to drink through a cracked straw. just make sure that you mount your mas after it
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-15-2004, 06:38 PM
where can i get another breather
ashah000's Avatar
Don't have a MAS, 2g NT uses a MAP sensor
You can get a breather at autozone for $10 in a variety of colors
Old 09-15-2004, 06:41 PM
sorry i didnt know you were nt.
-1stGenRocks-
Old 09-15-2004, 06:45 PM
so what your saying is all i need is another breather to plug up the other whole
Old 09-15-2004, 06:49 PM
exactly
-1stGenRocks-
Old 09-15-2004, 07:26 PM
george536's Avatar
you can get a breather or just plug the whole if youd like.
-1990 Eclipse GSX
Old 09-15-2004, 08:25 PM
one more question guys what is the little black rubber strap thing that comes with the cold air intake it is right next to the blue hose in the picture.
