Old 09-15-2004, 04:27 PM
forcefanajd's Avatar
forcefanajd forcefanajd is offline
Banned
Send a message via AIM to forcefanajd
swapping b18a1
im swapping a b18a1 into my 91 hatch....motor came from a 91 tegi....i grabbed the fule injection wiring harness fromt he tegi as well with the resistor box and the fuse panel on the passenger side shock tower.....i have the pr4 ecu too...now....is this gonna be a "plug and play" operation wiring wise...meaning i can plug in the connection on the drivers side and screw the wires coming from the fuse panel into mine and ill be good to go??? if not wut else do you see that i need?
Old 09-15-2004, 04:31 PM
Banned
Re: swapping b18a1
also has anyone heard good or bad things about HCP motor mounts??? supposedly they give you the most rooom for a turbo application and they have 4 mount point rather than the usual 3....just looking into them for now....also there is another comany call az engineering...anyone use those mounts?
Old 09-15-2004, 05:15 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Re: swapping b18a1
I had HCP 4 mount kit on my crx and i LOVE THEM! I had no problems with them whatsoever. The reason it has more room cause it sits much lower than Hasport or any other mounts. Its also tilted back just a lil to get that extra room in the front. I was happy with them and lots of ppl are to. I hardly hear any bad things about HCP.
About the swap. Its all plug n play bro. Its easy.
Old 09-15-2004, 05:22 PM
Banned
Re: Re: Re: swapping b18a1
thanks bro
Old 09-15-2004, 05:38 PM
mellowboy's Avatar
Re: swapping b18a1
No prob...keep us updated on the swap.
Old 09-15-2004, 05:41 PM
anthony90si anthony90si is offline
Re: swapping b18a1
you gonna have to dent the frame right under the shock tower to clear the alternator. and you shifter linkage won't bolt up. thats what i can think of for now. good luck
Old 09-15-2004, 05:47 PM
mellowboy's Avatar
Re: swapping b18a1
Well he never mentioned not getting an aftermarket shift linkage? And your right u do have to smash the wall on the alternator side so you'll have clearance. Somehow lots of ppl always forget that part lol
Old 09-15-2004, 05:48 PM
mellowboy's Avatar
Re: swapping b18a1
Oh the shift linkage will bolt up if you cut an inch off if i remember correctly.
Old 09-15-2004, 05:58 PM
Banned
yeah im getting the hcp motor mounts and linkage combo....and i knew about the bashing...should be fun
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
don't have to do this with AZraceMachine mounts. Best mounts IMO and they don't cost that much 280.00 shipped to ur doorstep in a week. No axle bindage and locates the motor in its stock position as if it were a dseries motor. they also sell linkages for 137.50 shipped.
best products i've ever seen or used. The only other company to engineer their mounts identical to the way hasport does. They were actually around before hasport.
about the plug and play thing...that all depends on if your car is a dx or si or std.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 09-15-2004, 06:11 PM
mellowboy's Avatar
Re: swapping b18a1
I still have no problems with HCP. They're like 310 shipped when i got them.
Old 09-15-2004, 06:38 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
Re: swapping b18a1
Its Plug And Play If You Have An Si.....if Its A Dx...then You Have To To The Mpfi Wiring
89 DX: LS Powered
88 CX: Project ZC
Old 09-15-2004, 06:44 PM
Re: swapping b18a1
is it the same if it would be a 92 teg.
Old 09-15-2004, 06:45 PM
Banned
LIKE I SAID I HAVE THE MPFI HARNESS FROM THE TEGI.....IM GONNA GET THE HCP MOTOR MOUNTS AND THE SHIFT LINKAGE FROM THEM.
Old 09-16-2004, 05:06 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
if its from a 92 teg u gotta rewire for obd1. As far as i know its just the dizzy wiring and the computer wiring. www.locashracing.com has ecu and dizzy adapters so u dont have to rewire.
1991 Honda Civic DX Sedan
