Old 09-15-2004, 10:13 AM
theevilstickboy theevilstickboy is offline
Angry High Mileage
Hey, whats up everyone. My 1989 Civic Dx has high mileage-187,456 to
be exact. Do ya think driving easy would be a good ideas. And what
could I do to make it run strong and long??? Also my older sister had it
before me and she was a really crazy driver that hardly ever took good
care of it.
p.s. I don't have very much money
THANKS
Old 09-15-2004, 10:45 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: High Mileage
Well as long as there no oil leaks, do a major tune up, check the compression. If everything is healthy then its all good. You have nothing to worry about. Just keep it well maintained. Maybe in the future you can swap in another motor. I'd suggest the sohc vtec or if you can't come up with that kind of money...then d16a6 would be dOpe!
Old 09-15-2004, 10:48 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: High Mileage
It depends on the actual shape of the car. My car has almost that many miles but I have replaced the engine and transmission over time (but I always drive it like I stole it). A couple things to look at...
Look at the engine... any leaks? where are they coming from? basic tune up is a good idea (ie. spark plugs, wires, cap and rotor... not too much $), change the oil (I use Castrol 10w-40), make sure all the grounds are nice and tight, check the belt for wear/cracks/etc., clean/replace the air filter element, exhaust rusty? replace it (cheapest is custom job from muffler shop... 2"), check codes if any from ECU.
Jack up car and get under it... inspect the transaxle... does it leak?, check out the axle boots/cv joints... any cracks/wear?, inspect the upper and lower ball joints bushings... any cracks/wear?
Also, look for rust... rust kills our cars.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 09-15-2004, 11:09 AM
yeah it has a brand new oil 10w 40, new air filter, new brake fluid and i clean the spark plugs good but there is a alot of rust mostly under the car. The brakes are rusted to shit and i needed a mini air;jack to loosen the wheel off.
Old 09-15-2004, 12:28 PM
dagoEF's Avatar
dagoEF dagoEF is offline
I'll suggest fuel filter and tranny fluid change as well.
Old 09-15-2004, 10:27 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Re: High Mileage
I agree with all the above, but the most important, in my opinion, is check for rust first. If the car doesn't cast a shadow anymore all the other stuff is a waste of money you can put toward another 4th gen Civic that isn't a rusty death trap. GL
Old 09-16-2004, 12:30 AM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
Re: High Mileage
drive the shit outta it.....my sedan had 550,000 kms before it called it quits....and even then it only had 4 oil changes in its life....and never had a fuel filter changed....it was ragged....2 owners since new....and I knew em both.....I only swapped outta it cause I was too lazy to repair the blown head gasket.
89 DX: LS Powered
88 CX: Project ZC
Old 09-16-2004, 09:26 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
iv got 216608.2 miles on my car ....and i drive it like i stole it....all the time. you just have to take care of it. the only thing that didnt like the 7000 rpm was the tensioner for the ac compressor.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 07-15-2006, 02:13 AM
doobie98 doobie98 is offline
Re: High Mileage
do yall think 146,000k is bad mileage for an 1989
Old 07-15-2006, 02:16 AM
Re: High Mileage
do you think 146,000k miles are bad on an 1989 car?
Old 07-15-2006, 02:22 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Re: High Mileage
I agree with all of the above, and would stress the compression test/tune up. That will give you the true condition of the motor. Mine had twice your mileage before I pulled it. And even with bad rings on two cylinders I was still going strong.
If it's a daily driver that you don't plan to mod or beat on, you should be fine with normal maintenance. If the motor is tired, be easy on it while you save for an inexpensive swap...
Old 07-15-2006, 12:22 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: High Mileage
No that kinda mileage isnt bad. Are you saying too low or too high? Cause for an 89 146k is either just right or on the low side.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 07-15-2006, 01:02 PM
allstar323 allstar323 is offline
Re: High Mileage
Drive it like you stole it..jk but my dad's 89 civic lx with 265,000 (just reached it last night) is still running strong. A whole mess of creaks and groans though. I occasionally drive it to 5k rpm like once in a month for fun. 185k is not that high compared to mine. I'm hoping to get to 300k without changing the timing belt...which needs to be changed.
edit: I read the part where your sister was crazy with it. Well we took care of this car (up to a point.)
If you want it to run, just do the required maintenence..timing belt, water pump, etc. But then there comes a point where its just not worth it anymore, like my car.
My car needs timing belt, water pump, oil pan gasket, heck, a full rebuild would be great.. It burns oil so use a higher viscosity oil to reduce burning...but see all that money is more than the car is worth. I'd use it on my 93 teg.
