View Poll Results: can you help
help me 1 100.00%
help me 0 0%
Voters: 1. You may not vote on this poll
Old 09-15-2004, 09:54 AM
joelmaups-dime joelmaups-dime is offline
Send a message via AIM to joelmaups-dime Send a message via MSN to joelmaups-dime Send a message via Yahoo to joelmaups-dime
4.3 motor problems
Ok heres my problem i hop you can help me- one day i was working on the body of my blazer then when i went to start it to leave it wouldnt start. i tested the fuel preasure and it only had 35 psi so i automatically assumed the fuel pump went out. Later i found out that my friend didnt unhook the battery when he was welding on it. I let the blazer sit for a day and it started kindof hesitantly but it started and i got it home. But now my abs light is on and so is the e-brake light im really thrown off on this hopefully one of you can help me.
Old 09-15-2004, 10:12 AM
atomicpulse's Avatar
atomicpulse atomicpulse is offline
Re: 4.3 motor problems
Don't you need to disconnect the battery when welding on a vechical so you do not short out the computer??
Old 09-15-2004, 01:39 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Please post at least the year of your truck and what fuel injection system it has.
Old 09-15-2004, 02:42 PM
OverBoardProject OverBoardProject is offline
Banned
Your abs light, and e-brake light might be on because of a shortage of brake fluid. If it's low look for a hole burnt in a brake hose, and also a quick brake check wouldn't hurt.
Old 09-15-2004, 07:12 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
A good rule of thumb is to disconnect the battery while welding,so is not welding within 12in. of the computer or laying your ground cable or feed cable(mig) over any of the wiring harness.Personally I welded on many cars and trucks and never had a problem yet without disconnecting the battery.
Old 09-15-2004, 07:16 PM
BTW I thought this was a poll??????????????
Old 09-16-2004, 06:56 PM
busa_4 busa_4 is offline
technically you are supposed to disconnect any control unit that is near the welding, not just the battery. the welder is a battery, so disconnecting the battery wont do much.
