Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 09-14-2004, 11:55 PM
gapboi210 gapboi210 is offline
Coolant Flush
I was reading, a few people have mentioned that they recomend flushing the coolant at 50,000. I am @ 53,000. Does anyone have instructions on how to do this? I know it has no radiator cap and am not sure if it has a drain plug. I also noticed a bleeder valve too.
Old 09-15-2004, 07:55 PM
bearcatdon bearcatdon is offline
Re: Coolant Flush
I believe it's on the LH side and you can put a 1/4" drive extension in it. Mine was so tight that the plastic plug started to deform so I flushed it via the lower rad hose. Make sure you use Dex-cool. The two types don't mix.
Old 09-15-2004, 10:01 PM
How do I refill the system since there is no radiator cap? Do I need to bleed the system?
Old 09-15-2004, 11:13 PM
Linkin12 Linkin12 is offline
Re: Coolant Flush
what i did with my 02..there's this little white screw on the bottom left..if you're looking from the drivers perspective..drained it and just refill
Old 09-16-2004, 12:09 AM
Yes,
But how do I refill it? Do I just keep pouring coolant in the recovery tank and let it suck it in? Do i need to bleed it, and if so how?
Old 09-16-2004, 04:19 PM
Re: Coolant Flush
Same way as if you had a rad cap. Fill the overflow bottle that will dump it into the rad. Bring the car up to operating temp, let cool and add more if needed. If your overflow bottle has fluid in it you know your rad is full
Old 09-16-2004, 11:17 PM
Should I keep the bleeder valve open while I do this? Then close it when fluid starts to come out?
Old 09-19-2004, 01:21 PM
Re: Coolant Flush
Once the rad is drained close the valve prior to adding any new fluids. Any air trapped in the system will eventually make its way to the overflow and get replaced with coolant. This is why it's crucial to verify the level after you ran the engine.
Personally I flush about 3-4 times with water to try and get all the old antifreeze out. I then fill it up with 100% antifreeze, run the engine to open up the thermostat and allow all the water that was in the engine to mix with the new antifreeze. Once the engine has cooled I verify the coolant freezing point and top off accordingly. Most times, you should get close to a 50/50 mixture. If your freezing point isn’t low enough you’ll have to do one more flush.
Old 09-24-2004, 06:36 PM
barry505 barry505 is offline
Send a message via ICQ to barry505 Send a message via AIM to barry505 Send a message via Yahoo to barry505
Re: Coolant Flush
Please read your owners manual for recommended maintainence rather than relying on what a few people say. GM cars have had Dexcool extended life coolant since the mid 90's and it's good for 5 years or 150,000 miles (or is it 100,000 miles, can't remember).
Old 09-24-2004, 07:38 PM
Yeah I am going to really rely on what GM says. AC controls panels that fail in almost every Malibu, brakes the constantly warp, cars that overheat. Sorry but I would rather spend $8.00 on a gallon of Dex-Cool than have my motor overheat. I am concerned about flushing it because I am about to make a 3200 mile trip in 5 days.
Old 09-24-2004, 10:07 PM
Re: Coolant Flush
Well, I'm the parts manager in a Chevy dealership and can't remember ever selling an A/C control for a Malibu. What failed in the control? Brake rotors usually warp because people put the cheapest brake pads they can buy in the car. Soft pads, make more heat, warp rotors. Use GM's Ceramic pads.
Old 09-25-2004, 12:03 AM
There has to be a hundred posts about the AC control panel going bad. They go between reciculate and open air when it feels like it and the AC light flashes off and on. The rotors warp all the time. Even with the original pads. There has to be hundreds of posts about this too. And your a parts manager for Chevy?! Never heard of these problems? Maybe thats why the have never redesigned the control panel and you have to keep buying and replacing them.
My extended warranty is probably hoping that my car would just disapear!
Old 09-25-2004, 12:19 AM
Re: Coolant Flush
I'm not saying it doesn't happen, but it might not be as common as everybody thinks. We see alot of problems in this forum, because almost everybody that posts, has some sort of a bitch. I don't see that many problems with the Malibu in the dealership, and I think that would be more typical of the cars that are out there.
By the way, I drive a 2000 Malibu with 60,000 miles on it. I did have to replace the blower resistor once, and the front pads and rotors were replaced at about 50,000 miles. Nothing else yet (knock on wood).
Also, although extended warranties can save your butt, as a rule, you pay more for the warranty than the repairs would ever cost in the same time period. Why do you think the dealers push them so hard? They are a profit center.
Old 09-25-2004, 10:36 AM
Re: Coolant Flush
Barry:
You may not see many of the problems being that lots of them occur after OEM warranty. This is probably the reason that GM hasn’t fixed lots of these issues. I work for a Tier 1 supplier and trust me no OEM likes to pay warranty and will insist on a fix from the supplier once it becomes a high hitter on the list. Been there done that.
My 99 Malibu has 90K on it and has had most issues that have been discussed. The A/C control and resistor are more inconveniences then anything else. You learn to live with them which most people probably do. Hitting the open air and recirculate button will normally kick the a/c back on. Using fan speed 3 as a low and regulating the temperature can usually make it comfortable in the vehicle.
Get your intake gasket on order your time is coming up with 60K on your vehicle. At least GM eventually realized this issue and recommended that the outer bolts be torqued higher to stop the intake from warping like a banana.
Old 09-25-2004, 11:00 AM
I bought my extended warranty through the finance company that I work for. So far they paid to have the motor pulled and rebuilt at 39,000 miles, replace power window regulator, now the ac control panel. I paid $1100.00 for the warranty and they have paid about $3000.00 in repairs so far. I look at my Honda Accord; 199,984 miles when I traded it in. Not ever a problem. Normal maint. was all that I had to do.
