Old 09-14-2004, 10:38 PM
carnut04 carnut04 is offline
dupli color clear
is it okay to spray duplicolor clear over tamiya decals?
thanks
Old 09-14-2004, 10:47 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: dupli color clear
If you used microsol to put them on, Yes. But spray VERY light coat's. If you spray too heavy you might melt them. If you didnt use microsol to put them on then it wont work.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 09-15-2004, 01:21 AM
sjelic's Avatar
sjelic sjelic is offline
Don't know for Tamiya but I ruined my Italeri decals with it even with sol, so I wouldn't recomande it at all.
Sasa Jelic
SCALEMAKERS
Old 09-18-2004, 05:07 PM
is it a must to use dupli color primer with dupli color paint? its my first time painting with duplicolor.
thanks
Old 09-18-2004, 05:13 PM
pre98zetec's Avatar
yea, I've tried it with other primer and it "ate" through them, So be safe and use all dupli-color products.
-Josh-
Old 09-18-2004, 06:30 PM
Vric's Avatar
Vric Vric is offline
I tried it once.. the film around the decal don't "desapear" and doesn't look great. but it didn't made any reaction. try it on a scrap part first
Old 09-18-2004, 06:32 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
I used dupli-color clear on my Richie Ginther F1 car with no problems at all!, dupli-color will go over anything, just remember to mist the first coat on. Then take it from there, and apply as many coats as you want.
I use it on all of my models
Old 09-19-2004, 12:32 AM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
If I could tack a 'rider' onto this thread... Does Dupli-color go over Tamiya Sprays or is it a big no-no? Dupli-color is so much cheaper and I've had success with it over automotive sprays.
I work slowly!
Old 09-19-2004, 12:35 AM
DSM-Mark's Avatar
Re: Re: dupli color clear
Why do you have to use microsol? I'm just very curious about this...
I work slowly!
Old 09-19-2004, 12:56 AM
pre98zetec's Avatar
Well with my experiance, spraying it over decal's without microsol on them the clear has ate the decals away. If i use microsol on it, it doesn't happen.
-Josh-
Old 09-19-2004, 09:02 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
i've used dupli color on decals before. Works fine. Oh yeah, i've mixed paints before. IE i use Dupli Color Primer with Plasti-Kote and Tamiya paints. I've also used Krylon Primer with Duplicolor Paint.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
