Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 09-14-2004, 10:01 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Is it blown?
My amp just suddenly stop working, and right before I had volume pretty low so i was not bumping loud at all. All connections are perfect. When i turn the ignition on the red light will come on for a sec. then fade away n not work. Is the amp blown? it is also about a week old
Old 09-14-2004, 10:13 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Is it blown?
turn off the car, disconnect the sub from the amp (just unhook the speaker wires from the amp), turn on the car and see what it does
if it does the same thing, check the fuses, namely the one in the power wire by the battery
if it goes green and stays that way, your sub might be blown
is there any chance you have a multimeter?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-14-2004, 11:10 PM
Mannyb18b's Avatar
Re: Is it blown?
i checked all the fuses...checked out good. I dont know wut a multimeter, im goin ot a shop that has one tom. so i will try to disconnect the speaker wires tomorrow, but even if the subs were blown would that still have that kind of effect on the amp
Old 09-14-2004, 11:23 PM
sr20de4evr's Avatar
Re: Is it blown?
yes if the subs were blown it would do what you described, but so would a multitude of other things
as for the fuses, superficial inspection says nothing, the only way to be sure that they aren't the problem is to replace them. What style fuse is in your main power wire? Is it a flat fuse with a spade terminal on each end, or is it a fuse inside a glass tube with a metal condom on each end?
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-15-2004, 06:26 PM
BlaZeNSmoKe BlaZeNSmoKe is offline
@ metal condom....Sorry can't help ya in this area, I need help myself so I'm out.
"BlaZe Has SpoKen"
Old 09-15-2004, 09:06 PM
Mannyb18b's Avatar
Re: Is it blown?
i disconnected the speaker wires, and the amp did the same thing. I have the kind in a clear tube with metal ends.
Old 09-15-2004, 09:17 PM
Mannyb18b's Avatar
Re: Is it blown?
actually i only checked the fuses on the amp. wut should i look for on the fuse on the power wire??
Old 09-15-2004, 10:05 PM
sr20de4evr's Avatar
Re: Is it blown?
You can't really look for the problem, you have an AGU fuse, and they're known to just stop conducting sporadically. You have to replace it to see if it's the problem, I had AGU fuses in my last install and I had 3 of them die on me like that. They didn't blow, I think the part where the fuse connects to the metal cap just broke apart. AGUs are crappy fuses....
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-15-2004, 10:29 PM
Mannyb18b's Avatar
Re: Is it blown?
alright cool, but do these symptoms mean that the amp did not blow?
Old 09-15-2004, 10:38 PM
sr20de4evr's Avatar
Re: Is it blown?
you mean that you disconnected the speaker wire and the amp stayed in protect? Well that means the subs aren't the problem, the only choices that leaves are
1 - something is wrong with the amp's power/ground/remote wiring
2 - the amp is fried
if the amp is fried, then you need to find what killed it so that it doesn't happen again
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-15-2004, 11:18 PM
Mannyb18b's Avatar
Re: Is it blown?
the red light will come on, along with the other blue lights that light up the speaker wire connections, but after a sec. they dim off. If the amp is fried, can it be fixed or do i need a new one?
