Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-14-2004, 09:36 PM
mikester_91 mikester_91 is offline
Distributor??
My lude has been feeling like it's been misfiring lately. And when i'm driving sometimes and i step on the gas, it hesitates and jerks bad for a split second. It does that over and over again. Sometimes i'll try to start it and it won't fire or will start quick and die. Also, when i pulled up to a stop sign the idle revved up slow and dropped down quick. Then saturday night i was driving and slammed on the gas and a huge cloud of black smoke came out.....smelled like oil bad...did the same for awhile while it was idling.... But it doesn't smoke now.....has a new timing belt and has been tuned up....the shop put it on the computer and said that it was definitely the distributor, but a want a second opinion before i fork out 300 plus bucks. Any ideas?
-92 lude si 129,000 miles
Old 09-15-2004, 10:23 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: Distributor??
The thing that I see wrong with this picture is that a check engine light (CEL) was not on, and they somehow read a code for that.
Check the voltage on your spark plug and spark plug wires to make sure they aren't fouled, and make sure the firing order is correct.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 09-15-2004, 04:32 PM
Re: Distributor??
How do you check the voltage on the plugs and wires? and how do u make sure the firing order is correct?
Old 09-16-2004, 07:48 PM
joellthomas joellthomas is offline
Re: Distributor??
Black smoke=unbured fuel.
Old 09-16-2004, 10:40 PM
Re: Distributor??
So would that be the distributor?
Old 09-19-2004, 04:13 PM
Re: Distributor??
if the fuel isn't burned it comes out black smoke. if the distributor is missing that bad, then the engine will be running very rough. my daughters distirisbutor died, but it started making a loud noise. sounds like you may have injector/fuel problems.
Old 09-19-2004, 11:05 PM
dbebesi's Avatar
dbebesi dbebesi is offline
Re: Distributor??
if it's a h23 i'll sell you a used distributor for 150 plus shipping.
Old 09-20-2004, 10:03 PM
Re: Distributor??
It IS making a very loud noise.
Old 09-21-2004, 06:19 PM
Re: Distributor??
I would get me a distributor.
Old 09-21-2004, 09:50 PM
Re: Distributor??
HMMM yeah i should probably...today at the chinese drive thru it felt like it was missing and about to die.
Old 09-24-2004, 10:02 AM
hondaprelude88 hondaprelude88 is offline
Re: Distributor??
I would start with a cap and rotor before the entire distributer, also test plugs wires. Somthings fouling out there along the way, if it misses under hard acceleration its most likely a wire.
Old 09-24-2004, 12:19 PM
Re: Distributor??
It misses under hard acceleration, but it also idles weird and feels like it's cutting out while it's idling. It's making a very loud noise in addition.
Old 09-24-2004, 12:22 PM
Re: Distributor??
Spark plugs were just changed professionally like 2000 miles ago. I changed the wires like 6000 miles ago becuz the others were OEM. How do you check the wires tho?
Old 09-24-2004, 08:14 PM
spedwezl's Avatar
spedwezl spedwezl is offline
Send a message via AIM to spedwezl
Re: Re: Distributor??
mine did the same thing, somethin was coming undone in my distriputer, needed to cap and rotor i believe.....helped out right away
Don't fall asleep or we'll mutilate your genitals.......
Old 09-29-2004, 05:25 AM
thomasortiz thomasortiz is offline
Send a message via AIM to thomasortiz Send a message via Yahoo to thomasortiz
Mike91
Hey mike... it seems that no one mentioned a clogged fuel filter. That could also cause these symptoms I would think... Or maybe a vapor lock or H20 n the lines. The smoke could be from trash burning up when it gets through the filter as well as the hesitation and acceleration failure. What do u think?
