Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 09-14-2004, 09:03 PM
hungryman54 hungryman54 is offline
Question 1989 T-2...fuel relay?
New fuel pump installed. Worked fine for 1 week. Engine turns over,but will not start. A shot of ether , she turns over. All fuses are OK. Put 12 volts to the pump,OK. Could it be the relay ? Stuck at my Buddies garage.
Old 12-22-2004, 07:38 PM
rust bucket rust bucket is offline
Re: 1989 T-2...fuel relay?
I have similar problem. Turns over fine. Spark is good. Fires up with ether, but won't run. gas fumes from tail pipe, did you ever get it going? seems to die with cold weather change.
Old 01-28-2005, 01:26 PM
nidansan nidansan is offline
Send a message via Yahoo to nidansan
Re: Re: 1989 T-2...fuel relay?
Is the check engine on solid even after crancking. I had a similar problem and it turned out to be a bypass cable fuse in the front of the engine by the battery cable (small black box - cable like fuses inside). Check them with a volt meter even if they look fine. This problem drove me crazy for a week or so even though I inspected them visually.
Good luck!
Old 02-01-2005, 05:18 PM
Lightbulb Re: Re: 1989 T-2...fuel relay?
Hey! guess what happened? My connecting link from my fuel pump to my fuel tank was faulty. Wired it direct removing the connector. Never had a problem since. It is on the right rear tire well. Good Luck and Have fun!!
Old 03-06-2005, 05:44 PM
Daq Daq is offline
Have you got it runnin? I'm in the SAME boat! AAAAARRRRRGGGHHHHHHHH!!!!!!!!
Old 03-25-2005, 10:52 PM
Yes, it was the connecting link from my fuel pump. Located at right rear wheel well. Removed link and wired direct. Not a problem since. I hope this is helpful.
Old 07-28-2005, 09:55 PM
89trooper 89trooper is offline
i guess this is a common problem for these years. my brother 88 had the same thing. maybe i should check mine out.
email me at [email protected]
