Old 09-14-2004, 07:40 PM
3KGT98 3KGT98 is offline
Send a message via AIM to 3KGT98
My Car Schreaches
I Own a 1998 Red Mitsubishi 3000GT SL (Automatic ><). The car has 56,000 miles on it and has not had the 60k service performed on it. When i accelerate fast and reach about 5000 rpm's, my car screaches for about two seconds. All i know is it doesnt sound good and it comes from the front of the car (engine duh). Just wondering if anybody else has had the same problem or knows what it might be. Thanks.
Represent
Old 09-14-2004, 08:13 PM
Gateway's Avatar
Gateway Gateway is offline
Re: My Car Schreaches
check to see if the fan belt is loose? any belt for that matter?
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 09-14-2004, 08:28 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
my sisters had a small oil leak in the camshaft and when she would accelerate hard the pressure would spill the oil onto the belt causing it to slip. but yeah man that sqeal is comming from one of the belts.
Old 09-14-2004, 09:24 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Might want to cough up the cash and do that 60k service sometime soon.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 09-14-2004, 09:25 PM
alright
Could you explain to me where the belts are located, and how to tighten them back up if i found that one was loose. I have only had this car for about a month, and this is only my sencond post so i thank everyone for their help.
Represent
Old 09-15-2004, 12:24 AM
sLADe781 sLADe781 is offline
I had somewhat of a similar problem with my AC belt. When I had my AC on, it'll start squeaking and when I stepped on the gas, it squeaked even louder. I had it changed and it's ok now. My belt was old and "cracking" even if it didn't look too bad. Try spraying some WD-40 on 'em and if they stop squeaking for a bit then it probably is one of the belts. My belts were located on the right side of my engine...but I have a '94 SL so I don't know if it's located at the same place as yours. Good luck.
Old 09-15-2004, 11:13 AM
the belts are on the driver side of the engine. pop the hood and you will see the belts between the motor and the sidewall. jack up the car. remove the driver-front tire. remove the plastic splash-guard. the belt tensioners will be right behind the splash guard. tension then up or down to tighten/ loosen. its easy.
